high idle on vvti 1jzgte
Postby FLAWLES » Wed Feb 25, 2009 10:47 pm
just done a engine tranplant into my chaser
runs mint bar the 4000rpm idle.
i think its the idle up valve but am really un sure
mine seams to be jammed open i think
is this a comin thing on 1jzgte?
if not anyone got ideas?
FLAWLES
Postby postfach » Wed Feb 25, 2009 10:51 pm
On mine, the only things that ever caused this were:
Idle control valve stuck open
Vacuum leak
postfach
Postby FLAWLES » Wed Feb 25, 2009 10:52 pm
how did you fix the valve? or did you replace it?
FLAWLES
Postby postfach » Wed Feb 25, 2009 10:54 pm
I replaced it twice, and they all crapped out, I ended up blanking the hole with a bit of 5mm ali and joining the hoses together.
Check your vac hoses first, the one I've had trouble with before goes to the steering rack.
postfach
Postby FLAWLES » Wed Feb 25, 2009 10:57 pm
will do that
block it off aye? mmmm and it ran ok with no issues?
FLAWLES
Postby strx7 » Thu Feb 26, 2009 10:06 am
there is NO power going to the Idle solenoid stepper motor thing in the throttle body - thats if they run the same type of set up as the 1JZ and 2JZ GE pre vvti. I know when i got my surf going i had a 2500rpm idle. put power to the idle motor and it closes and then you can control it from there. Also sounds like you have a vacuum leak or the TB is jacked open.
Postby RomanV » Thu Feb 26, 2009 1:55 pm
Yeah I'd say vaccum leak, I doubt the ISCV could flow enough air for a 4000rpm idle!
Postby rollaholic » Thu Feb 26, 2009 5:35 pm
with the ISCV blocked it will idle okay when its warm, cold mornings will be a pain though
Postby postfach » Thu Feb 26, 2009 7:56 pm
rollaholic wrote:with the ISCV blocked it will idle okay when its warm, cold mornings will be a pain though
It's not as bad as you'd think, mine happily idles as soon as I start it, just have to watch it doesn't stall when you let off, but after a minute or 2 its fine. With mine, once I've made it from my driveway to the end of the road (maybe 200m) it will hold idle perfectly.
postfach
Postby FLAWLES » Fri Feb 27, 2009 8:21 pm
cheers for the help
got it sorted
pulled it apart took the plunger out and sealed it up, runs fine now
FLAWLES
