ct20b rebuild?
ct20b rebuild?
Postby MR2SIK » Fri Feb 27, 2009 4:03 pm
Just out of interest, can a ct20b be rebuilt with better internals for more power the same way a ct26 routinely does?
Also, what would I expect to pay to get a ct20b rebuilt/refreshed to factory specs?
Cheers.
2011 Ford Mondeo tdci.
1990 MR2 GT garage queen
MR2SIK
Postby Boosted_162 » Fri Feb 27, 2009 4:08 pm
Ceramic CT20b rebuilt with a ST205 WRC steel wheel is about $800, i cant remember the exact figure. Thats with oversized bearings, new seals etc. Can find the receipt if your keen.
Was done by Alltech.
Postby MR2SIK » Fri Feb 27, 2009 6:52 pm
Yeah, that would be great thanks,
so is that allow it to be more efficent/make more power, or just be more reliable in handling higher boost levels for longer?
MR2SIK
Postby Boosted_162 » Fri Feb 27, 2009 7:12 pm
MR2SIK wrote:Yeah, that would be great thanks,
Nah that was just back to standard. The steel wheel will allow more boost before shattering, but the ceramic ones do hold up pretty well. The oversized bearings were cos of wear and tear, standard size had too much play or something.
Postby Boosted_162 » Fri Feb 27, 2009 7:30 pm
Ok, found the receipt.
Got oversized bearings because the standard ones were worn, and the compressor wheels came in contact with the housings.
It got: ST205 steel turbine wheel, bearings, piston rings, o-rings and got balanced. Total cost was $873.56
Postby MR2SIK » Fri Feb 27, 2009 7:48 pm
Cheers for that.
So does anyone know if the ct20b can be improved upon the same way the ct26 hybrids do? or is it a case of a ct26 being upgraded from factory and becoming a 'ct20b'
MR2SIK
Postby Boosted_162 » Fri Feb 27, 2009 7:56 pm
MR2SIK wrote:Cheers for that.
If you want more power, get a GT3071R :lol: :lol:
If my 180SX doesnt sell, ill put the T56 masterpower turbo onto my MR2 hahaha.
Postby MR2SIK » Fri Feb 27, 2009 10:09 pm
yeah that was the plan lol, now moneys a bit tight, and want to go do things with my life so put the car up for sale, it decides to throw a hissy fit and i gotta fix a few things before I feel comfertable selling it to anyone :lol: I'd make a shit car salesman lol
MR2SIK
Postby levinguy » Fri Feb 27, 2009 10:17 pm
pm phothog on here, he knows all about turbos and can sort you out for a rebuild
levinguy
Postby MR2SIK » Sun Mar 01, 2009 10:43 am
Boosted_162 wrote:Ok, found the receipt.
I had to read your project page about 3 times to keep track of what turbo you're running lol.
out of interest, what are you doing with your ct20b now?
MR2SIK
Postby Boosted_162 » Sun Mar 01, 2009 11:41 am
Haha yeah, i kept on changing my mind :lol:, ended up biting the bullet and putting the T3/T4 on. CT20b is in the garage, but im not planning on selling it sorry :P. Got plans for it eventually :D
Postby Akane » Sun Mar 01, 2009 1:42 pm
So far there is no ct20b "upgrades" that I know of to make it better, because the CT20b actually has a smaller compressor housing than a CT26 AFAIK, there's not much room for you to put a better compressor wheel.
Postby Phothog » Mon Mar 02, 2009 12:39 pm
The CT20b cant be upgraded as easy as the CT26,
because of the Bore where the compressor wheel runs.
the T04E Upgrade on the CT26 is fine because the compressor wheel bore is sligtly smaller than the CT26...
but the bore on the CT20B's is smaller than the T04E or even the GT2871 compressor wheels...
there is a way round it. but its a bit dodgy.
Chris.
1999 ST215W GT-T 325,000kms still going strong.
2000 M201G YRV Turbo, 1300cc little pocket rocket.
Need a Turbo Rebuilt or Upgraded... send me a email Chris @ Turbo.co.nz
Phothog
Postby FLAWLES » Mon Mar 02, 2009 12:51 pm
FLAWLES
Postby steve murch » Tue Mar 03, 2009 8:26 pm
Akane wrote:So far there is no ct20b "upgrades" that I know of to make it better, because the CT20b actually has a smaller compressor housing than a CT26 AFAIK, there's not much room for you to put a better compressor wheel.
ct20b and ct26 have the same comp cover,and as chris says you can do upgrades
steve murch
