7agte building
7agte building
Postby gleem » Mon Mar 02, 2009 9:32 pm
I have a spare blacktop head, 7afe block and some odd turbo parts. So obviously these all go together nicely. The question is what can a stock 7afe bottom end handle power and psi wise? and also are there any low cost swaps gor these like ze pistons etc. I can see theres a size difference in rods etc and if anybody has any advise on possible problems etc, thanks
gleem
Postby Dell'Orto » Mon Mar 02, 2009 9:44 pm
Not much, 7AFE rods are pretty spindly.
Postby gleem » Mon Mar 02, 2009 9:45 pm
are there any upgrades without buy new forged ones
gleem
Postby Dell'Orto » Mon Mar 02, 2009 9:48 pm
Not that I've heard about, you could see what other motor has a similar stroke and try find a rod that has the same big end and pin height :lol:
Otherwise Spool rods arent too badly priced.
Postby sergei » Mon Mar 02, 2009 10:21 pm
There is a fatter 7AFE rod. later model one that came in caldina. This all from memory I read somewhere on internetz so I might be wrong.
Postby matt dunn » Mon Mar 02, 2009 11:17 pm
there are a lot of rumours of different rods working,
some honda models, GTX mazda, Even GSR Lancer,
but none are simple and all require machining.
I tried through most of the rumoured to fit one and never found anything.
and the 7a's I had apart were late model ones and the rods are still
way too weak looking.
Postby gleem » Fri Mar 06, 2009 7:33 pm
what ones did you end up using
gleem
Postby matt dunn » Sun Mar 08, 2009 10:07 pm
I ended up with ARGO rods in mine.
http://www.argorace.com.au/
Dad got them direct when he was over there working.
Postby Bazda » Mon Mar 09, 2009 9:37 am
Just get the spool rods, only $550!! friken cheap.
How good they are though.. no idea..
As I always say, if your gona build a 7agte you better save up some cash. Everyone things it will be cheap to build but as you build you will need to do a alot more than you think.
