blacktop died error code 14
Postby johndoe1025 » Fri Mar 06, 2009 6:57 pm
my turn to ask now! unfortunately :(
the levin died this avo, cruising downhill i thought i heard some funny noises, looked at my speedo to see the engine check light on, i downshifted and as i did so the engine stalled and wouldnt restart. now, if i turn the ignition off, then back on and crank, itl fire then die, then itl just crank till i turn the ignition off again. throwing up error code 14 - ignition signal? anyone had experience with this problem on a blacktop before and have any info/instructions on where to look? thanks
EP82 GT-went mega hard for completely stock, 15.09 quarter, gone now :(
AE111 Levin BZG current! 4AGTE next? you never know....
johndoe1025
Postby Twolitre » Fri Mar 06, 2009 7:10 pm
I'd be starting with swapping for a known good ignitor and if no luck then perhaps dizzy but I think dizzy failure with Toyota's is pretty rare.
You're an auto sparky aye, maybe ask some of your colleagues?
Twolitre
Postby johndoe1025 » Fri Mar 06, 2009 7:13 pm
they had all gone by the time i got it back to the workshop, and i checked out some books to do tests but all the plugs and stuff they specidied were different (older 4afe, not 4age) my 1st suspicion was the coil but i dnt relly no, was hoping someone had encountered the problem already so i could get a head start. i just want it to go, its only got to last another month....lol
johndoe1025
Postby RS13 » Fri Mar 06, 2009 7:17 pm
Yeah, error 14 is the ignition code. I had that recently, my car would momentarily cut out when taking off, took all the plugs off the igniter, coil etc, blew them out, problem gone. However, I would say your problem was more serious! Remove the plugs, give them a clean etc, then if no change try another ignitor and coil, no change, try the dizzy.
RS13
Postby Boosted_162 » Fri Mar 06, 2009 7:53 pm
I had an error 14 code on the GT4 when i got it - ended up being the ecu.
Postby johndoe1025 » Fri Mar 06, 2009 8:21 pm
the plugs are new, installed them when i had the motor apart, leads arnt much older either.... so its gotta be coil dizzy ignitor or ecu. really hope its just the coil or something lol
johndoe1025
Postby MR2BOY23 » Fri Mar 06, 2009 10:49 pm
Sounds like the same thing that happend to my silvertop. ignitor coil? ecu
EDIT: actually sounds like the exact same thing
MR2BOY23
Postby johndoe1025 » Fri Mar 06, 2009 11:46 pm
what did it enf up being on your silvertop? i take it ecu
johndoe1025
Postby MR2BOY23 » Sat Mar 07, 2009 12:34 am
Yup. Had to change the igniter and coil to get it started though, but ecu was buggered ever since then.
MR2BOY23
Postby johndoe1025 » Sat Mar 07, 2009 10:53 am
hmm. went to it this morning, started fine, wich makes me think its a heat related issue as it died as it was getting warm
johndoe1025
