Changing brake lights - ST183
Postby GTTpower » Tue Mar 10, 2009 7:10 pm
Ok my brother has a ST183 Celica and the brake light bulbs need replacing, had a look in the boot and covering the lights is a big steel body panel with wires coming out, and for the life of me I couldnt figure out how to change them out.
Is there an obvious/easier way of doing it that Ive missed?
1999 SXE10 Altezza RS200Z
2004 Honda SCV100
Previous: 1993 EP85 Starlet, 1984 KP60 Starlet
Steam/Origin ID: nzEP85
GTTpower
Postby Bling » Tue Mar 10, 2009 7:13 pm
General rule of thumb on removal of parts is to unbolt things until what you want off.... falls off.
Surely lights can't be THAT complicated.
Postby GTTpower » Tue Mar 10, 2009 7:16 pm
BZG|Bling wrote:General rule of thumb on removal of parts is to unbolt things until what you want off.... falls off.
Looking for an answer thats a bit more specific but thank you, thats usually what I do anyway :lol:
2004 Honda SCV100
GTTpower
Postby Bling » Tue Mar 10, 2009 7:21 pm
Then you should have fixed it already ;)
Postby Boosted_162 » Tue Mar 10, 2009 7:58 pm
Do it from the outside of the car, not the inside. Start by pulling the vent bit off from the side iirc. Cant remember where the bolts are, but i do remember its a sealed unit seperate from the car, and you need to take the cluster out to change bulbs.
Postby Scotty » Tue Mar 10, 2009 10:57 pm
there are screws under the vent on the corner
Scotty
