Caldina GTT steering alignment
Postby archie » Mon Mar 23, 2009 10:16 am
Can anyone help me with the factory steering alignment figures (Toe in / out, Camber, Caster ) for a 1997 Caldina GTT? :)
Archie
archie
Postby cedwards » Tue Mar 31, 2009 7:01 pm
probably a bit late but here's what my last alignment sheet had on it:
Specifications:
front: Min / Max
Caster 0.5 / 2.00 degrees
Camber -1.08 / 0.42
Toe -0.3 / 0.9
total -0.6 / 1.7
Rear:
Camber -1.58 / -0.08
Toe 0.6 / 1.7
total 1.1 / 3.5
Secondary Angles:
SAI 13.33 / 13.33
cedwards
Postby archie » Sat Apr 04, 2009 8:38 am
Thank's for that :D I'll use it as a comparison for my GTT, Ive got a slight shake on the steering which is not the wheel balance :?:
Archie
archie
Postby cedwards » Sun Apr 05, 2009 8:20 am
warped brake disc?
cedwards
Postby archie » Sun Apr 05, 2009 10:03 am
No, Discs all replaced nice and tru, but one possibility is that when I bought it the aftermarket wheels did not have any spigot rings fitted which may have caused the wheels to run slightly off centre wearing the tyres unevenly, although there is no uneven wear to see, it would'nt take much, and the tyres are to good to replace at the moment!
What tyre pressures would you recomend with a 205/55/16 tyre, the standard pressure or something else?
archie
