RWD 20v 4age ignition
Postby ke_25 » Mon Mar 30, 2009 11:15 pm
Hey,
im process of converting 20v blacktop to rwd, have sorted out all the water piping but now need to sort out the ignition, just purchased a distributor for it and have real along the lins of coverting to wasted spark etc but did not get any firther,
so wanting some help on this,
the ecu i will be runnign is a link g4 also, if this is any help
cheers shaun
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby Bazda » Tue Mar 31, 2009 11:46 am
plenty of info on the net. Search google. I did this a while ago and there are pages of this type of conversion
Postby ke_25 » Tue Mar 31, 2009 12:27 pm
i did search on the net, and everytime it comes back into relation to the rwd water piping system. or converting a 16v dli to work with factory ecu, i want to know whats involved to run aftermarket ecu
i have read u canb run no cap and run dizzy as a cas, but unsure if pickups etc need to be made?
ke_25
Postby Bazda » Tue Mar 31, 2009 1:14 pm
ke_25 wrote:i did search on the net, and everytime it comes back into relation to the rwd water piping system. or converting a 16v dli to work with factory ecu, i want to know whats involved to run aftermarket ecu
You can just run the dizzy as the cas, its just a magnetic reluctor interface. Then you just gota make sure the ECU has the interface to work with a toyota 4age 20v magnetic multi tooth setup.
Easy as that.
Postby ChaosAD » Tue Mar 31, 2009 5:46 pm
Fairly sure matt dunn on here has done it, theres pics in his project thread.
Use a pair of evo 1-3 wasted spark coil packs or similar, they take the standard HT lead plug so you would need some new leads.
Remove the dizzy cap and rotor from the dizzy and get a cap machined up to cover it and it (should) clear the firewall.
Im not sure if you use the evo ignitor or link ignitor, I think I read something about getting a weak spark using the evo ignitor with the link (could have been an old LEM though).
ChaosAD
Postby gasman » Tue Mar 31, 2009 6:56 pm
i dont seem to be having any problems running the evo ignitor with evo coil packs controlled by a g3. which leads me onto my next point of i got a set of coil packs and ignitor for sale if your interested.
"What can possibly go wrong?"
gasman
Postby ChaosAD » Tue Mar 31, 2009 7:04 pm
ChaosAD
Postby matt dunn » Tue Mar 31, 2009 10:50 pm
ChaosAD wrote:Fairly sure matt dunn on here has done it, theres pics in his project thread.
Yeah i did it.
If you have a link then 90% of the hard part is done.
Use a dual channel igniter, either mitsi or link,
just not a toyota one as they are not compatable,
and some double ended coils, mitsi or similar.
Then it's just a matter of setting it up in the link.
You siad G4 so it will run it all fine.
Run the dist with or without a cap or cover if you want,
makes no difference to the running of it,
just need to keep stones and fingers out of the pickup.
HT leads are the only problem.
I converted the std leads to suit, but you need to mount the coils right there to do it.
Postby ke_25 » Tue Mar 31, 2009 10:58 pm
hey,
cheers for help~~ yeah i have already aquired a mitsi ignitor and have some new evo bosch coils from when i was going to run 16v with crank angle set up,
i juts thought mayb you need a pick up for it to know which position the distributor is in, but sounds like it has pick ups built into the dizzy,
so is it just a matter of wiring it correctly from the pin outs on the distributor?
cheers for help
ke_25
Postby Fireball » Mon Apr 06, 2009 6:33 pm
Hi
Did you have any problem with the dizzy and thermostat housing hitting the firewall, (this is for an ae86) Just finished building turbo blacktop, would like to know if this is an issue before i put the engine in.
thanks
So many cars so little time
Fireball
Postby ChaosAD » Mon Apr 06, 2009 7:26 pm
Apparently the dizzy will fit without the cap/rotor but the t/stat housing is an issue.
http://www.rollaclub.com/board/?showtopic=14024
http://www.club4ag.com/technical_main.htm
ChaosAD
Postby Fireball » Tue Apr 07, 2009 12:52 pm
Thanks for the link, the way i was thinking of doing it was really wrong.
Fireball
Postby ROBODISCO_20v » Tue Apr 07, 2009 6:44 pm
You'll also find lots of useful info over at www.club4ag.com
This article may help http://www.club4ag.com/faq_and_tech_pag ... %2020V.htm
ROBODISCO_20v
Postby The Last Streetfighter » Tue Apr 07, 2009 7:11 pm
My Ride: 2001 Caldina GT-T Manual ;)
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
