1jz-ge no spark - anyone in waikato good with 1j's ?
Postby docTRD » Tue Mar 31, 2009 1:03 pm
hey all ive just finished putting a 1jz-ge and auto from a jx90 into a gx71 cressida and ive wired it all up using factory diagrams etc. this is my 2nd cressida project but last one was a 1ggte.
its got fuel but no spark from the plugs, have done the basic test against an earth when cranking, nothing.
Have checked B+ and earths to ecu etc and main efi relay is working, just seems like ive missed an input to the ecu or something? maybe from the auto ?
if anyone knows much about 1j/2j engines and is close Id be very grateful for some help. cheers
Daily : st191 corona liftback mmm room
Project : Jzx90 mark2 Tourer V
--- wtd: corolla GT ae92 sedan ---
"Mum i knw its another wreck, i only got it so i can put the seats in the lounge" YEAH RIGHT
docTRD
Mo Joe
Postby strx7 » Tue Mar 31, 2009 1:11 pm
are you getting output from the dizzy?
wiring
Postby docTRD » Tue Mar 31, 2009 5:40 pm
im not sure aye, is that the Ne signal? shouldnt it be already wired up in the engine loom? goes to the ecu i think. hmmm might haveto check that.
any thing else that i might have missed?
which wires do you need to get the engine going then I can check from there.
docTRD
Mo Joe
Postby docTRD » Thu Apr 02, 2009 9:54 pm
hey strx7 yeap getting a signal from the dizzy to the ecu, its around 200mv.
Also checked the wire that is called "IGF , RPM 1" from the ecu, output to ignitor ? had 5V on it.
Wire called RPM 2 had no voltage on it, not sure if its used on a non turbo 1j.
any ideas ?
also Im running a speedo cable into the auto instead of the electronic sensor as the cressida has a cable driven speedo in the cluster, the lack of the electronic plug being on the sensor would that stop it from firing up? just a thought.
docTRD
Mo Joe
Postby strx7 » Fri Apr 03, 2009 10:10 am
unfortunetly thats about where my knowledge of std JZ things ends cause i've only used them with aftermarket ecu's
Postby Jonno2002 » Fri Apr 03, 2009 12:50 pm
docTRD wrote:also Im running a speedo cable into the auto instead of the electronic sensor as the cressida has a cable driven speedo in the cluster, the lack of the electronic plug being on the sensor would that stop it from firing up? just a thought.
nope thats just the SPD sensor, mine still isnt hooked up after 6 months, all that happens is the CEL (check eng light) comes on occasionally when going over 80kmh.
have you got power to the coil and ignitor ?
all i do when haxxing up looms is bypass all the relays and just supply power to the ecu/coil/ignitor/fuel pump and works everytime :P
Jonno2002
ecu
Postby docTRD » Sun Apr 05, 2009 2:23 pm
yea haha i could just bypass all the relays etc but i wanted to use them as it makes it bit more factory and its all fused etc. i dont have a pinout for my ignitor where can i get one?
docTRD
Mo Joe
Users browsing this forum: Bing [Bot], Google [Bot] and 13 guests
