Making/fitting fuel tank
Postby cat007 » Fri Apr 03, 2009 8:08 am
Hey all
I'm thinking of building/making an aluminium fuel tank to sit in the same location as the stock one, but I want it to not be so tall as the OEM one pokes down too low
Would I need a cert for this?
Postby Paulio » Mon Apr 06, 2009 11:09 pm
You may be in luck.
"LVV certification is not required provided that:
• no structural modifications have occurred to the vehicle during the installation or modification, and
• the fuel type has not changed."
Page 9: http://www.ltsa.govt.nz/certifiers/virm ... -13-v3.pdf
But thats just the rules anyway.
Paulio
yees booy
Paulio
Postby neo » Mon Apr 06, 2009 11:59 pm
I looked into this, you will only loose tank volume by doing this, unless you modify the floor (in a corolla anyhow)..
neo
Postby cat007 » Tue Apr 07, 2009 9:06 am
I have no problem with loosing volume! I'd be happy to go from 70 to 40 litres, if it meant I can make a decent under tray :)
