Hilux calipers
Hilux calipers
Postby cat007 » Sat Apr 04, 2009 9:28 pm
I've searched but for the life of me cant find anything!
I remember reading a while ago about hilux/surf calipers
What disk size could or should I use for my *A70 Supra?
Cheers!
Postby Prymal » Sun Apr 05, 2009 10:31 am
hmm this might be a good one for a search on toymods ..
i know yu can modfy Ford Au brakes ( thnk massive brembo's on the later tickford/te50's) to a cressida of the same age as your supra , maybe you can do the same for the yours, and earlier ma61's - OR use nissan R33 Brembo's as well
same stud pattern , though you would need to use different caliper adaptors, but it has been done - im just ot sure of the technical aspect but i kno at least 5 cars done this way on Toymods in Australia
Prymal
Postby cat007 » Sun Apr 05, 2009 11:22 am
classique71 wrote:hmm this might be a good one for a search on toymods ..
thanks for that. I've asked on toymods.
I guess what keeps putting me off changing calipers/disk/pads is that my disks are pretty new already and my pads are very new Mintex 1166's - so don't want to waste them lol
Again, thanks for the advice
Postby l1ttle_d3vil » Sun Apr 05, 2009 2:24 pm
im using hilux calipers, supposedly with ford falcon rotors. definitely hilux calipers, but im only going on what the previous owner has said regarding the rotors. they're 11.25" vented anyway, should be some pics in the projects section.
Postby cat007 » Sun Apr 05, 2009 2:59 pm
l1ttle_d3vil wrote:im using hilux calipers, supposedly with ford falcon rotors. definitely hilux calipers, but im only going on what the previous owner has said regarding the rotors. they're 11.25" vented anyway, should be some pics in the projects section.
ah bugger - well my rotors are 297mm as it is - so that's a downgrade lol
Postby sponsormycrown » Mon Apr 06, 2009 4:37 pm
i have hilux calipers on my crown running dba 2 piece rotors 295x25 i think off the top of my head.
The space between the bolts is 90mm and the original disc i thnk is 20mm i fitted spacers to mine.
There is also 2 different types of the calipers. 1 has smaller pistons and runs a thinner disc. (which is the ones i got)
the other i think has 2mm bigger pistons and 25mm disc from factory, this is from memory tho and when i was looking for mine i couldnt find any of the 25mm ones at all.
They also need quite a bit of "offset" on your disc for it to work. as the front half of the caliper is huge like 40mm or so so the hat on your disc needs to be quite decent.
how were cars built without the internet in the 90s?
sponsormycrown
Postby escortman » Mon Apr 06, 2009 6:08 pm
on mates ute hes running the 4pots and evo4 discs
4x4 toyota blizzard offroader
escortman
Postby cat007 » Mon Apr 06, 2009 6:10 pm
escortman wrote:on mates ute hes running the 4pots and evo4 discs
that's what I was after!!!!!
Can you please find out what calipers they are? LN130's etc? And what size the disks are?
Thanks :) :)
Postby escortman » Mon Apr 06, 2009 6:17 pm
Thanks :) :)
um not sure if hed be able to remember what hilux theyr off, got em from pikapart but they are the 4pots, will find out disc size they are rather big even behind his 19s
escortman
Postby escortman » Mon Apr 06, 2009 6:19 pm
i thinks 310mm just evo4
escortman
Postby l1ttle_d3vil » Mon Apr 06, 2009 7:13 pm
escortman wrote:um not sure if hed be able to remember what hilux theyr off, got em from pikapart but they are the 4pots, will find out disc size they are rather big even behind his 19s
are the pistons same size, or two bigger and two smaller on each caliper?
Postby escortman » Mon Apr 06, 2009 7:40 pm
unsure sorry
escortman
Postby cat007 » Mon Apr 06, 2009 8:02 pm
Don't suppose you'd be able to pass on the details of this mysterious person? I'm very keen to find out details....
Postby escortman » Mon Apr 06, 2009 8:21 pm
what specs ya after?
escortman
Postby l1ttle_d3vil » Mon Apr 06, 2009 9:13 pm
from what I've gathered off the net, LN61 / LN65 have staggered pistons (far left).
Late LN106 and LN130 have same size pistons (far right).
Not sure what the ones in the middle are off.
Pretty sure LN61/LN65 take skinnier disks too (possibly solid???). I originally had LN130 calipers and changed to LN65, ended up having to mod the centre part of the caliper to widen where the disk runs. Hope this makes sense. Might help in identifying the caliper from just looking at it - they take different pads too, so it helps to know what model you've got :lol:
Postby cat007 » Mon Apr 06, 2009 9:14 pm
escortman wrote:what specs ya after?
well - how are they for one :)
How thick are the disks?
Postby escortman » Mon Apr 06, 2009 9:46 pm
l1ttle_d3vil wrote:from what I've gathered off the net, LN61 / LN65 have staggered pistons (far left).
i think theyr the middle 1s
escortman
Postby escortman » Mon Apr 06, 2009 9:48 pm
before he put turbo mark 2 booster in it didnt really like stopping with discs on rear as well, but now its rips ur face off haha
will find out thickness tomorrow 4 ya
escortman
Postby Looonie » Mon Apr 06, 2009 10:02 pm
*ponders doing something with the hilux 4 pot calipers and discs sitting in the garage*
Rumple dee pumple dee doo...
Looonie
Postby cat007 » Mon Apr 06, 2009 10:04 pm
Looonie wrote:*ponders doing something with the hilux 4 pot calipers and discs sitting in the garage*
gizz!!
