Diff Help
Diff Help
Postby varix » Tue Apr 07, 2009 9:32 pm
Im looking to get an LSD into my 88 GX71 Mark II. Im pretty sure it currently is an F Series Diff. Is it possible to fit an F Series altezza lsd diff head strait into this housing? If not what are my options?
Just lsd diffs from same era supras, mark 2s and cressidas?
varix
Postby mint ke35 » Thu Apr 16, 2009 9:29 pm
I've been told that if its the same series it will fit. assuming it physically fits in the housing.
viewtopic.php?t=66317
mint ke35
Postby varix » Fri May 15, 2009 1:28 am
Right so I have a GX71 MarkII with a F282 IRS differential. I have just today sourced a F253 nonIRS LSD differential.
What I want to know is will the new F253 bolt strait into my F282 IRS housing? Obviously one being IRS and one not?
Also from what I can tell my current diff has a 4.3 ratio and the new diff has a 4.556 ratio? What difference will this make to drivability?
varix
Postby postfach » Fri May 15, 2009 1:47 am
You can just swap the original crown gear over onto the LSD head to keep the ratio the same. I'm fairly sure the G series heads are interchangeable between IRS and non IRS, so it's probably safe to assume the same goes for F series.
postfach
Postby strx7 » Fri May 15, 2009 7:40 am
yeah you just put your original crown wheel onto the lsd carrier, along with the side bearings front your original, set it back up in your original head casing/housing and you'r away laughing. if you dont know what your doing with preload etc i'd suggest you consault someone that does
Postby varix » Fri May 15, 2009 10:36 am
Awesome thanks heaps guys. I think Its fair to say I can go ahead and buy it and it shouldnt be to hard to find someone who knows what they are doing to swap the parts between the two diffs.
varix
