MR2 Boost when hot
MR2 Boost when hot
Postby thornz » Sat Apr 11, 2009 7:34 pm
During todays trackday, I noticed that after a few fast laps, the boost was dropping from its usual pressure. Its completely standard car, and usually boosts around 8-9 psi, but after a few laps, it was dropping to aorund the 5-6psi level. What could be the cause of this? Would it just be the heat build up in the engine bay? Or is there a more serious issue behind this? Any suggestions for troubleshooting this?
thornz
Re: MR2 Boost when hot
Postby sergei » Sat Apr 11, 2009 7:43 pm
thornz wrote:During todays trackday, I noticed that after a few fast laps, the boost was dropping from its usual pressure. Its completely standard car, and usually boosts around 8-9 psi, but after a few laps, it was dropping to aorund the 5-6psi level. What could be the cause of this? Would it just be the heat build up in the engine bay? Or is there a more serious issue behind this? Any suggestions for troubleshooting this?
I assume this is 3SGTE?
do you get CEL when that happens?
I assume it is in limp mode, thus "bleed" VSV is disabled.
Or perhaps something simple as intercooler is not up to task and inlet tempt is too high hence limp mode.
Postby thornz » Sat Apr 11, 2009 7:53 pm
Im assuming CEL is a warning light?? Nothing came up on the dash, and yes its a 3sgte. Hmmm, limp mode would sound correct, as when the car isnt up to temp, its boosts to the same level.
thornz
Postby Twolitre » Sat Apr 11, 2009 8:11 pm
Jumper TE1 and E1 of the diagnostic terminals in the engine bay and if you can't decipher the codes then tell us how many times the check engine light flashes inc long pauses.
What mods have you done?
Twolitre
Postby iOnic » Sat Apr 11, 2009 8:29 pm
There won't be any stored CEL codes if the CEL isn't on. That and it won't be in limp mode unless he hits boost cut (he'd definitely know about that and he certainly wouldn't hit boost cut on a 100% factory engine @ 9psi)
Sounds like heatsoak on the stock intercooler.
Postby thornz » Sat Apr 11, 2009 8:36 pm
iOnic wrote:There won't be any stored CEL codes if the CEL isn't on. That and it won't be in limp mode unless he hits boost cut (he'd definitely know about that and he certainly wouldn't hit boost cut on a 100% factory engine @ 9psi)
Heatsoak was my initial thoughts as there was no warning lights, and the car still ran fine. And on the way back home once it had sat cooling for a while, it was back running full boost.
So is there a cure for the heatsoak apart from fitting a bigger cooler?
thornz
Postby Boosted_162 » Sat Apr 11, 2009 8:40 pm
The cheap and rangi way to do it, is by disconnecting the air temp sensor on the engine lid. The fan on the intercooler then runs permanently.
Postby thornz » Sat Apr 11, 2009 8:46 pm
I like rangi if its free and works :lol:
One other quick question, I'm gonna do a oil and filter change this week some time. Where is the best place to dispose of waste oil? Do most dumps have a place to dispose of it?
thornz
Postby KwS » Sat Apr 11, 2009 8:53 pm
a couple of the ones in chch do. uh, the one over wigram way does for sure. There is one that doesnt.... its over ferry way, but cant remember what that area is called. atleast, they didnt when i was last there.
KwS
Postby thornz » Sat Apr 11, 2009 9:06 pm
KwS wrote:a couple of the ones in chch do. uh, the one over wigram way does for sure. There is one that doesnt.... its over ferry way, but cant remember what that area is called. atleast, they didnt when i was last there.
Cheers mate. :D
thornz
Postby Twolitre » Sat Apr 11, 2009 9:06 pm
Not all codes put the CEL on. It's quick and easy to check your ecu for codes to eliminate other possibilities.
Surely a heat soaked intercooler wouldn't cause the turbo vsv to close would it?
Twolitre
Postby AJz » Sat Apr 11, 2009 10:27 pm
i would have said boost leak but if its fine on the way home that doesnt make sense.
you could try disabling the vsv but of course you would need to give it death to get it real hot, thats assuming next track day is a while away.
ya havnt had any probs before taking it on the track ?
I had vtax :(
AJz
Postby fivebob » Sat Apr 11, 2009 11:04 pm
Twolitre wrote:Surely a heat soaked intercooler wouldn't cause the turbo vsv to close would it?
Not on a Gen II 3S-GTE, there's no manifold temp sensor ;)
The VSV will close if the engine temp is too high or too low, or if the intake air temp is too low.
Postby Twolitre » Sat Apr 11, 2009 11:51 pm
So therefore whether or not the IC was heatsoaked would not be causing the lack of boost. It is more likely that the water temperature was too high or the sensor itself may even be faulty.
If there's no codes and everything checks out you may as well block off the vsv and run an aftermarket boost controller.
Twolitre
Postby thornz » Sun Apr 12, 2009 1:04 pm
AJz wrote:i would have said boost leak but if its fine on the way home that doesnt make sense.
When I first got the car, the malfunction warning lamp came on, which turned out to be just some loose wiring, which put it into limp mode. But since then have had no dramas whatsoever with it.
Its a gen1 3sgte if that makes any difference?
thornz
Postby iOnic » Sun Apr 12, 2009 1:19 pm
It's a Gen2 3SGTE and a Gen1 SW20. MR2's don't come with the Gen1 3SGTE - ST165 Celicas do
Postby thornz » Sun Apr 12, 2009 2:20 pm
iOnic wrote:It's a Gen2 3SGTE and a Gen1 SW20. MR2's don't come with the Gen1 3SGTE - ST165 Celicas do
Ahh okay :oops:
thornz
Postby Akane » Sun Apr 12, 2009 5:03 pm
IIRC you get that when excessive knock is detected, it happened to me many times when I was down at meremere during the day, but less during the night, I have my boost set to 1.1bar and at times drop to 0.5bar when this happens, the VSV disables.
If I get a clean run I'll get mid to low 13's, but when it happens (most likely on 2nd gear after the launch), I'd get mid 15's.
It goes:
1) Lineup
2) Launch 1st gear, moderate wheelspin all the way to 6krpm, boost is normal at 1.1bar
3) chop to 2nd, boost stuck at 0.5bar
4) If I play with the throttle a bit, let it off and back on, sometimes it'll come right back to 1.1bar
Try retard timing a bit and see if it helps.
Postby Twolitre » Sun Apr 12, 2009 6:05 pm
Akane do you run an aftermarket boost controller AND the vsv plumbed in together?
I don't know of anyone who's managed to do that and maintain constant boost levels. It is the norm to disable the vsv when running an aftermarket boost controller.
Twolitre
Postby MAGN1T » Sun Apr 12, 2009 6:38 pm
Another possibility is an exhaust leak. Cast manifolds can warp and unseal but only when excessively hot. No you won't nessecarily hear it either.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
