thornz wrote:During todays trackday, I noticed that after a few fast laps, the boost was dropping from its usual pressure. Its completely standard car, and usually boosts around 8-9 psi, but after a few laps, it was dropping to aorund the 5-6psi level. What could be the cause of this? Would it just be the heat build up in the engine bay? Or is there a more serious issue behind this? Any suggestions for troubleshooting this?
iOnic wrote:There won't be any stored CEL codes if the CEL isn't on. That and it won't be in limp mode unless he hits boost cut (he'd definitely know about that and he certainly wouldn't hit boost cut on a 100% factory engine @ 9psi)
Sounds like heatsoak on the stock intercooler.
thornz wrote:iOnic wrote:There won't be any stored CEL codes if the CEL isn't on. That and it won't be in limp mode unless he hits boost cut (he'd definitely know about that and he certainly wouldn't hit boost cut on a 100% factory engine @ 9psi)
Heatsoak was my initial thoughts as there was no warning lights, and the car still ran fine. And on the way back home once it had sat cooling for a while, it was back running full boost.
So is there a cure for the heatsoak apart from fitting a bigger cooler?
KwS wrote:a couple of the ones in chch do. uh, the one over wigram way does for sure. There is one that doesnt.... its over ferry way, but cant remember what that area is called. atleast, they didnt when i was last there.
Twolitre wrote:Surely a heat soaked intercooler wouldn't cause the turbo vsv to close would it?
AJz wrote:i would have said boost leak but if its fine on the way home that doesnt make sense.
you could try disabling the vsv but of course you would need to give it death to get it real hot, thats assuming next track day is a while away.
ya havnt had any probs before taking it on the track ?
fivebob wrote:Twolitre wrote:Surely a heat soaked intercooler wouldn't cause the turbo vsv to close would it?
Not on a Gen II 3S-GTE, there's no manifold temp sensor
The VSV will close if the engine temp is too high or too low, or if the intake air temp is too low.
