Fxgt Auto probs - ANYONE? COMMON PEOPLE
Postby CelicaGT8 » Sat May 02, 2009 8:32 pm
AE101 FXGT, Auto will when put in drive will start in 1st then change to 4th.
Even if you floor it it will rev to 4500 then change to 4th
If you put it in 1st it will rev to 7000 then you can change it into 2nd (on the stick) and it will change into 3rd.
Basically it just wont get 2nd and wont use 3rd unless you put it into 2nd lol.
Any ideas?
CelicaGT8
Postby 85AW20v » Mon May 04, 2009 10:11 pm
Change the fluid for a start. If that doesn't fix it put a manual box in it.
See ya
Simon
85 MR2 20v
85AW20v
Postby CelicaGT8 » Thu May 07, 2009 1:23 pm
so much torque, if it was manual it could create a black hole vortex and implode the world... it is a silvertop after all...
CelicaGT8
Postby rollaholic » Thu May 07, 2009 1:29 pm
its $&#$% get another one
Postby CelicaGT8 » Thu May 07, 2009 7:44 pm
ya recken? not worth trying to fiddle with the kick down cable or replacing the trans fluid and filter?
CelicaGT8
Postby crispy'86 » Thu May 07, 2009 10:54 pm
Try new fluid and filter, well see what cokour your fluid is that comes out of it. If you have lots and lots of nice silvery film mixed with your fluid chances are the trans is kaput. But you could surprise yourself and fit the parts and actually have second and third
crispy'86
Postby AE86less » Thu May 07, 2009 11:38 pm
I stressed hardcore when my KE70 started doing that (and hunting for gears while cruising). Had $&#$% fluid in it cause of a leaking hose.
AE85.5
1GGZE GX81
D21 Navara K/C
AE86less
Mo' Fail
Postby sergei » Fri May 08, 2009 1:18 am
crispy'86 wrote:...cokour....
is that french for rooster :lol:?
Postby crispy'86 » Fri May 08, 2009 7:10 am
Yes congrats, you picked up on that one. Bit of a late night and long day at work doesn't help things :oops:
crispy'86
Postby crispy'86 » Fri May 08, 2009 7:12 am
And probably check your kickdown cable adjustment aswell accelerator cable
crispy'86
Postby rollaholic » Fri May 08, 2009 7:59 am
how does the kickdown cable affect how it shifts up gears?
can you select 2nd and third off the stick without the 7k rpm carry on? does it drive normally in those gears when they are selected?
unless the fluid is low as AE86less mentioned, i doubt changing it is going to do jack. and will probably cost the same as a secondhand trans. (who wants autos right)
it sounds like a valvebody problem to me
strange for toyota trans to fail though!
Postby CelicaGT8 » Fri May 08, 2009 10:18 pm
Im not a fan of autos at all, but it was cheap and i was roadcarless,
It has never been in 2nd sinc iv had it, it will go into 3rd if you put it in 2nd on the stick, lol
If you try to drive it normaly, it will just go from 1st to 4th when 1st gets to 4500rpm, or less, depending on your foot.
Fluid looks clean and is on the cold full mark when cold.
Excel cable is good, kickdown tells the auto what position the excel is in. so it can change up when you floor it depending on rpm
Im so not going to change the box haha, it achually drives quite well... BUY IT!
CelicaGT8
