ae101 clutch
ae101 clutch
Postby method » Mon May 04, 2009 12:05 am
Im getting a new clutch and i have a ae101 flywheel and w55 box.
Are the ae101 flywheels 212mm diameter?
AFIK i need to use a 4AGZE clutch of some sort. Not sure if it is a recessed one or not, are the ae101 flywheels recessed? Reason for this is the clutch needs to fit onto the w55 spline.
Cany anyone enlighten me?
Thanks.
PICS UPDATED DAILY
method
Postby Mr Revhead » Mon May 04, 2009 12:34 am
all 4agze clutchs are recessed. its quite easy to tell them apart when you see them
4agze ae101 is 224 and N/A 212 iirc.
4AGZE flywheels are also pretty damn heavy!
http://www.csn.ul.ie/~eireae86/tech/eng ... ywheel.jpg
theres a 4agze one. note the raised lugs
and heres the two 20v ones, flat
http://www.my-acoustic.com/Car/weight_i ... ywheel.jpg
Postby method » Mon May 04, 2009 4:46 pm
Ahh cheers for that.
My car has the ae101 4age flywheel (NA) but i need a clutch that is not recessed but has the same spline count as the GZE clutch.
PICS UPDATED DAILY
method
Postby Mr Revhead » Mon May 04, 2009 4:49 pm
i dont think theres a stock toyota plate that will do that, but any clutch place worth their name will be able to make one for you easy enough.
ask around who is good in auckland.
Postby xsspeed » Mon May 04, 2009 5:29 pm
Autoclutch always seems to get a good rep
think thats there name, they made bazda's gear from memory
Postby rollaholic » Mon May 04, 2009 6:38 pm
yeah i've had a couple of their clutches too
good blokes
