Compression Test Done Resultss
Postby MR2BOY23 » Mon May 04, 2009 6:41 pm
Just did a compression test at work yesterday on my mr2 3sge
All 4 cylinders were around 180psi, im pretty sure this is a good reading ? Correct me if im wrong. But my car does blow some smoke after like 5000rpm and goes through around a litre of oil a month its not leaking any oil either
Thanks
MR2BOY23
Postby sergei » Mon May 04, 2009 6:43 pm
Worn oil control rings.
What colour is the smoke?
Could be worn valve stem seals as well.
Postby MR2BOY23 » Mon May 04, 2009 6:47 pm
The smokes isn't blue, its white
MR2BOY23
Postby DriftSpecStarlet » Mon May 04, 2009 7:35 pm
Blacks over fuelling, Blues oil, Whites usually Water/Oil :P
Toyota Celica ST185
Big f'n front mount,
Bodykit (actually looks decent)
Lowerd on blue Springs
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Location: Gisborne, New Zealand, Earth, Universe, Milky Way.
Postby MR2BOY23 » Mon May 04, 2009 7:42 pm
So white smoke doesn't indicate something other than what blue smoke would indicate?
Or are they the same thing rings/stem seals etc
MR2BOY23
Postby jakesae101 » Mon May 04, 2009 7:44 pm
useing any water?
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby DriftSpecStarlet » Mon May 04, 2009 7:56 pm
Well water doesnt do anything other than flow around things... If your using water it must be getting into the system... have someone follow you can make SURE it is white smoke... may just LOOK white in your mirrors..
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby sergei » Tue May 05, 2009 11:40 am
White smoke could be from leaky exhaust valve stem seals (oil+hot but not igniting). It also could be a mixture of of unburned oil + blue (burned oil).
Also white could be unburned fuel (leaky injectors), but that is highly unlikely as it would run like shit and consume enormous amount of fuel.
Also lots of fuel = apparent increase of oil level (due to oil being diluted).
