BOLTING A 3SGTE GEN4 HEAD ON GEN2 BLOCK???
Postby neelside » Tue May 05, 2009 12:13 pm
would any1 here know if a cylinder head off a gen4 3sgte out of a caldina gtt would bolt up to a gen2 3sgte block from a celica st185 ???
neelside
Postby fivebob » Tue May 05, 2009 3:08 pm
The head will bolt up to the block, but I think you may need to use a GenIII/Gen IV head gasket.
That said however, nothing else will bolt up, i.e. you need GenIII/IV intake and exhaust manifolds. It is not easy to run a distributor without a lot machining on the head, so you will also need to run an aftermarket ECU, add a crankshaft position sensor and run coil on plug ignition, or possibly wasted spark with twin coils.
comp
Postby neelside » Tue May 05, 2009 3:48 pm
its running a link g3 ecu atm.
neelside
Postby Prymal » Thu May 07, 2009 10:44 pm
youd be better off adapting the gen4 engine in and toughening up the block internmals- those are some meaty bores :)
Otherwise listen to 5bob
Prymal
Postby strx7 » Fri May 08, 2009 10:25 am
use the 4th gen but put EARLIER conrods in it
gen2
Postby neelside » Fri May 08, 2009 11:45 am
its currently got eagle rods,je pistons,os valves,hks vavle springs,272 cams,cam gears etc,but i keen going thru cometic head gaskets
i need to change the head gasket once again so im thinking about changing the head to a gen4 with the gen4 intake manifold if its a fairly easy change
neelside
Postby strx7 » Fri May 08, 2009 1:00 pm
Sounds like you need to work out why you are eating headgaskets
Re: gen2
Postby fivebob » Fri May 08, 2009 1:37 pm
neelside wrote:but i keen going thru cometic head gaskets
Are they copper gaskets?
I'd recommend using a stock Gen III gasket, they are better than most of the aftermarket gaskets available.
gasket
Postby neelside » Fri May 08, 2009 1:54 pm
yea ive found a TTE 1.4mm gasket just gotta wait for it to come from the states then see how it goes
neelside
gasket
Postby neelside » Fri May 08, 2009 1:58 pm
neelside
Re: gen2
Postby strx7 » Fri May 08, 2009 2:40 pm
Pretty much every forum ya look at people reccomend the std gasket, I haven't had any issues.
