LSD for E series rwd diff?
Postby Hachiroku » Wed May 06, 2009 3:02 pm
E series diff is 7.1" from Liteace, live axle Cressida etc. Just wondering whether Toyota ever made a LSD unit for them?
Hachiroku
Postby Boost_4_Life » Wed May 06, 2009 3:47 pm
baha yus they did, but good luck ever finding one... ive just changed my whole rear end in the rally car which was E series because after years of hunting i never found an lsd...
which also means i have 3 E series diff heads for sale if anyone wants them..
The rally beast
The rally beast again!
Boost_4_Life
Postby fangsport » Wed May 06, 2009 4:37 pm
ever thought of using the guts out of an R180 Subby/nissan diff?
i know the H165 head is the same spline as T (6.7") and can be fitted by re-drilling mounting holes (8 instead of 10).
i havn't tried yet, but suspect the same can be done with H190 and F (7.5").
i am sure a KP60 rally car i enquired about on Trade me had a hybrid nissan/subby/toyota solid axle with LSD.
fangsport
Postby Boost_4_Life » Wed May 06, 2009 5:19 pm
hmmm dunno. Need to come up with some sort of option like that... Ive just changed to rx7 diff. using econovan housing. picking beastie up this avo actually, lucky its wet outside get to try it out!!
Theres always the altezza/F series option and going aftermarket lsd..
The rally beast
Boost_4_Life
Postby Hachiroku » Wed May 06, 2009 6:56 pm
Bugger. I assume the fwd e series boxes aren't related at all?
Hachiroku
Postby rollaholic » Wed May 06, 2009 7:28 pm
no man, fwd diffs are completely different construction.
think F series will be your second easiest option
first being a mig
Re: LSD for E series rwd diff?
Postby NZ_AE86 » Tue May 12, 2009 1:43 pm
Hachiroku wrote:E series diff is 7.1" from Liteace, live axle Cressida etc. Just wondering whether Toyota ever made a LSD unit for them?
I have run an AE86 LSD in a liteace rear diff with a small adapter/spacer plate. You need to run custom axles to suit though.
Current rides;
1985 AE86 Race/Rally Car
1986 Levin GT
NZ_AE86
