sw20 3sgte > n/a g/box
Postby lucasthefallen » Sun May 10, 2009 5:15 pm
quick question. has anyone had any luck and or experience with fitting an n/a sw20 gearbox onto a 3sgte. im thinking closer ratios, but unsure wether the n/a box is strong enough.
will get an a/m lsd
lucas
Need Service or Repair work done? send me a PM
lucasthefallen
Postby MR2BOY23 » Sun May 10, 2009 5:26 pm
I think the N/a box is suitable for a standard 3sgte
But if your looking for more power then no
MR2BOY23
Postby levinguy » Sun May 10, 2009 9:24 pm
quite a few people in the uk get away with running them on v6 conversions when they're nice to them, so im sure if you have some sympathy for it, it should last, never done it myself though.
levinguy
Postby Boosted_162 » Sun May 10, 2009 9:33 pm
If im not mistaken you have to use an 3SGE clutch plate because the input spline is different. I recall Dave/RomanV destroying a 3SGTE clutch plate in his Beams SW20 for this exact reason.
Postby RomanV » Sun May 10, 2009 10:47 pm
yep :oops:
Was told they're the same, but they're not.
Need NA flywheel/clutch.
Also need NA driveshafts I think.
Postby kim0663 » Tue May 12, 2009 2:29 am
a guy i know over in torbay who did a v6 swap, killed the n/a box pretty fast and wasn't even able to take it in for a cert lol
he sourced a 3sgte box and is getting it certed now tho...
Mr2 GT-S
330ci M
kim0663
