Engine mount filler
Engine mount filler
Postby TRD_ZERO » Sun May 10, 2009 6:20 pm
My front engine mount is torn whhat can i use to fill it? Ive heard of people using some window goop. What could i fill it with to mybe make it solid?
Previous:
TRD_ZERO
Postby high_lux » Sun May 10, 2009 6:45 pm
buy a new one!
high_lux
Postby TRD_ZERO » Sun May 10, 2009 6:56 pm
Not really answering my question is it? The engine is going to produce a fair bit more power than the original one, buying a new one might have the same end result and tear. They look crappy and flimsy and i think a solid mount would be more suitable.
Previous:
TRD_ZERO
Postby MR2BOY23 » Sun May 10, 2009 7:14 pm
Yeah window silicone
Sikaflex hi temp stuff really durable
MR2BOY23
Postby Crampy » Sun May 10, 2009 7:19 pm
I'm thinking about making one with time-ex PRC from work.
If that doesn't work, then I'll get some urethaned.
Crampy
Postby TRD_ZERO » Sun May 10, 2009 7:23 pm
MR2BOY23 wrote:Yeah window silicone
Yeah i think thats the stuff im after. Do i apply it in layers so that it sets evenly or just lay it all in there and let it dry for a few days? Where abouts do i get it?
Previous:
TRD_ZERO
Postby MR2BOY23 » Sun May 10, 2009 7:40 pm
Supercheap or maybe bunnings
When my mate did it before his warrant he just filled it in and let it dry for a day, im not sure how its actually supposed to be done, but this worked for us
MR2BOY23
Postby Lloyd » Sun May 10, 2009 8:21 pm
Either get a new mount or get the old one out and done properly. Window silicone is not the way to do it at all
Postby Malcolm » Sun May 10, 2009 9:01 pm
haha, window silicon is a terrible idea. The stuff that some people use is the urethane cement used for holding windscreens in, not the same as silicon. Otherwise, buy some decent 2 part urethane to pour into it, or get autolign to do it
Postby tsoob » Sun May 10, 2009 9:15 pm
TRD_ZERO wrote:Not really answering my question is it? The engine is going to produce a fair bit more power than the original one, buying a new one might have the same end result and tear. They look crappy and flimsy and i think a solid mount would be more suitable.
dont use window silicone.
i just had mine done full noelathane, really hard BUT not cheap (around the $400 mark for 2) if you want come by the shop and ill show you the setup as its still out of the car but not far off going back in :)
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby levinguy » Sun May 10, 2009 9:19 pm
i've heard of people using the sikaflex stuff to do it with, but only ever lasted as a temp measure. as in only lasting 6 months with a good run. at the end of the day windscreen sealant is made to seal windows..
if you're worried about breaking standard mounts take your old one to plus plastics in east tamaki, it will take plently of power after they urathane it. last time i checked it was only $50 for them to do it, but has proberly gone up.
levinguy
Postby MR2BOY23 » Sun May 10, 2009 9:32 pm
Malcolm wrote:haha, window silicon is a terrible idea. The stuff that some people use is the urethane cement used for holding windscreens in, not the same as silicon. Otherwise, buy some decent 2 part urethane to pour into it, or get autolign to do it
Thats what I meant thats what sikaflex is a windscreen cement whatever you wana call it
MR2BOY23
Postby strx7 » Sun May 10, 2009 9:40 pm
fill it with windscreen URATHANE and then still it back to front - assuming its the front or rear mount that way the factory rubber will take more of the movement
Postby Mr Revhead » Sun May 10, 2009 10:08 pm
the front and rear mounts on ae101s and 111s dont do that much...
they are dampers for the fore-aft movement of the engine.
so you dont really need to urethane them.
although it has been said that soild mounts help transfer a little more torque through the drivetrain.
personally, i dont think they need to be strengthed for anything
BUT, if you do urethane it, do both as they work in pairs
Postby neo » Sun May 10, 2009 11:03 pm
Dont use any over the counter / single tube urethane types to fill the mounts. It will never set
Search for my old posts on this matter.
I got my mounts (new ones) filled by Thorndon Rubber here in welly for about $30-40 each).
Find a local place that fixes rollers / machine rollers as they will be mixing urethane to different shore ratings (nolethane is around 80 shore).
neo
Postby TRD_ZERO » Sun May 10, 2009 11:29 pm
neo wrote:Dont use any over the counter / single tube urethane types to fill the mounts. It will never set
Thats good info could you elaborate a little on rollers so i know where to search. Sorry if im missing the obvious.
Previous:
TRD_ZERO
Postby Mr Revhead » Mon May 11, 2009 12:57 am
neo wrote:(nolethane is around 80 shore).
75-100 :wink:
Postby AceSniper » Mon May 11, 2009 7:24 pm
just had my front and rear urethaned as I was tearing them, put my old torn mounts in a tin and burnt the rubber out of them then sent them away for urethane was $120 incl postage
AceSniper
Postby neo » Mon May 11, 2009 11:27 pm
levinguy wrote:if you're worried about breaking standard mounts take your old one to plus plastics in east tamaki
Machine rollers / printing rollers, anyone that makes / fixes resin coated wheels/rollers
neo
Postby molex » Tue May 12, 2009 12:36 am
+1 for plus plastics, had three done for $110
molex
