SW20 3sge Wheel Size
Postby Stu- » Tue May 12, 2009 11:24 am
A cousin has bought a tidy 3sge SW20 and is looking at buying a set of 17's for it. Can anyone let me know the common size tyres people run?
We fitted a rim off my Caldina running a 215/45/17 and on the front of the MR2 the tire rubbed on the spring seat so I'm assuming 40 profile 17's should be used?
Project Thread
Stu-
Postby mr2low » Tue May 12, 2009 2:15 pm
see here >> http://mr2.gordaen.com/wt_calc.php
or for more ideas and info here >> http://www.mr2oc.com/showthread.php?s=&threadid=137
or if your cousin has $$$$ you have "hellaflush" here>>> http://www.mr2oc.com/showthread.php?t=339447
basic tip please go staggered nothing worse then seeing an sw with massively tucked wheels at the rear
mr2low
Postby Stu- » Tue May 12, 2009 3:08 pm
Awesome, cheers for that.
Will have to register to the MR2 forum to read the other two links so will do that tonight.
Project Thread
Stu-
Postby Boosted_162 » Tue May 12, 2009 11:50 pm
Ive got 17x8/+36/235-40-17 front, and 17x9/+38/255-40-17 rear on mine. Only rub is the innter guard which isnt fitted properly anyway.
Postby Alex B » Wed May 13, 2009 12:16 am
Running 215/40/17 on the front, they only rub when i reverse on hard lock. Offset is around the 35-40 mark.
Postby MR2BOY23 » Wed May 13, 2009 9:10 am
Mine 17's are sitting super low and don't rub
215/45 r17 w87
MR2BOY23
