fixed back seats question
Postby jakesae101 » Tue May 12, 2009 9:22 pm
whats the law regarding back seats if i installed 2 fixed back seats in my ae92 gtz trueno do i have to remove my back seats or can i leave them they wont be operational bacause you wont be able to get into the back im going to get a half cage at some stage so they will have to go in i just want to get my bucket seats in
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby unstable » Tue May 12, 2009 9:28 pm
Legally you would need to register and cert your car as a two seater and remove the rear seats and belts.
2000 JZX100 Chaser
13.827@167kph@ Nightspeed.
Owner- Pit Stop Grey Lynn. PM for Quotes.
unstable
Postby Bling » Wed May 13, 2009 12:13 am
I thought the register part was an urban myth.
Postby sergei » Wed May 13, 2009 8:58 am
unstable wrote:Legally you would need to register and cert your car as a two seater and remove the rear seats and belts.
Load of crap.
What you need to do is:
Remove seats and seat belts.
Go for WOF when time comes.
Don't fill in the seat belt threads.
Don't need the cert.
There is no such thing as 2 seater registration.
If WOF guy is an idiot tell him to ring LTSA (or take your business somewhere else).
Postby jakesae101 » Wed May 13, 2009 7:04 pm
so i take it there is no way to get around not removing the back seats then
jakesae101
Postby rollaholic » Wed May 13, 2009 7:09 pm
if they arent going to be usable, why would you want to keep them in place?
Postby jakesae101 » Wed May 13, 2009 7:18 pm
bacause i dont want a hole ther i could make a new pannel up that id have to then remove again and redo when the cage goes in
jakesae101
Postby Stott69 » Fri May 15, 2009 8:54 pm
Who are you planing to get the shelf made throught?
Ill be back down next week and will try come to the local meet, could see if i can help you out if you need
Image jzs147 Aristo money pit
Stott69
Postby jakesae101 » Fri May 15, 2009 9:16 pm
i was going to do it i have a pretty good wood work setup at work that i can use but have little experiance in wood working so some help would be good
jakesae101
Postby Stott69 » Sat May 16, 2009 12:14 pm
I work with sheet metal but have a few years of frame and truss building up my sleeve
Stott69
Postby jakesae101 » Sat May 16, 2009 12:20 pm
can do it out of metal i thaught dimond plate painted black would be cool but i dont have any of the gear
jakesae101
Postby jakesae101 » Tue May 19, 2009 5:49 pm
scott scored some free sheetmetal (galv like they use in ducting) decided not to use checker plate after finding out its $14 for a peice 300mmx300mm of 3mm thick 8O
jakesae101
