Distributor fault?
Distributor fault?
Postby DriftSpecStarlet » Sat May 16, 2009 5:17 pm
I unbolted the dizzy from the head and turned the key to ignition
Spun the part thats connected to the cam and there was no spark or injectors "ticking"
I left the leads and plugs connected and dizzy plug and coil hooked up
Toyota Celica ST185
Big f'n front mount,
Bodykit (actually looks decent)
Lowerd on blue Springs
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Location: Gisborne, New Zealand, Earth, Universe, Milky Way.
Postby l1ttle_d3vil » Sat May 16, 2009 5:29 pm
not sure, but the dizzy MIGHT need to be bolted to the block so that its earthed before it will provide a spark.
Postby DriftSpecStarlet » Sat May 16, 2009 6:00 pm
But it should still be sending the signal to the Injectors to fire shouldnt it?
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby Mr Revhead » Sat May 16, 2009 7:09 pm
dissy earths through body.
no earth = no ign signal
no ign signal = no fuel
Postby matt dunn » Sat May 16, 2009 7:11 pm
l1ttle_d3vil wrote:not sure, but the dizzy MIGHT need to be bolted to the block so that its earthed before it will provide a spark.
No it doesn't, it should work without the body earthed,
but wouldn't say that's a good dist test anyway.
Could still be lack of power to the ECU,
Bad ECU earths, and a few other faults.
A faulty Dist will almost always put in a fault code,
so check that first.
Postby Mr Revhead » Sat May 16, 2009 7:12 pm
oh. well trust the sparky over me! :lol:
Postby matt dunn » Sat May 16, 2009 7:20 pm
Mr Revhead wrote:oh. well trust the sparky over me! :lol:
yeah, lol
Igniter cases must be earthed, but dist sensors are insulated from the body.
Postby ChaosAD » Sat May 16, 2009 10:25 pm
what engine is it?
ChaosAD
Postby DriftSpecStarlet » Sun May 17, 2009 9:29 am
3sgte
ill go out and have a jam this morning with it earthed just to eliminate that problem
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby DriftSpecStarlet » Sun May 17, 2009 6:25 pm
Yep no go with it earthed.. Do these units usually go faulty?
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby Lloyd » Sun May 17, 2009 6:35 pm
Any fault codes?
Postby DriftSpecStarlet » Sun May 17, 2009 6:40 pm
You mean if i turn the engine to IGN does Check Light show?
Then no it doesnt strange eh..
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
Postby matt dunn » Sun May 17, 2009 8:16 pm
DriftSpecStarlet wrote:You mean if i turn the engine to IGN does Check Light show?
the light should come on with the key on and engine not running,
if the dist is ok or not.
if no light, then it is a supply to the ecu, or ecu problem usually.
Postby DriftSpecStarlet » Sun May 17, 2009 8:28 pm
Okay no check light with either ECU Plugged in
Toyota Celica ST185
T3/T4 Turbo
BOV
All the gadgets!
DriftSpecStarlet
