jakesae101 wrote:discovered my spedo is about 9-10ks out at 100k anyone know where i can get this fixed in wellington
cat007 wrote:Robinson Instruments in Auckland can do it
If you give them how much out it is and what fittings they should use - and what car its for - they can make you a step down/up box
jaypines wrote:you can get the kit from jaycar. http://www.jaycar.co.nz/productView.asp?ID=KC5435&keywords=speedo&form=KEYWORD
adjust to the desired percentage you want. but in your case, error is not linear so i guess just adjust it to speed you want it most accurate.
~SlideWays~ wrote:jaypines wrote:you can get the kit from jaycar. http://www.jaycar.co.nz/productView.asp?ID=KC5435&keywords=speedo&form=KEYWORD
Not for cable driven speedo's though.
