Or some way to modify the ones i have... any ideas?
I have swaped the hubs around so the arms are at the front.
I know the corona GTR hubs have the tie rod ends join from under the arm but i still need it lower than that.
Mr Revhead wrote:bin the whole celica set up
use something from a RWD car including lower suspension arms.
thats your best bet to get a set up that hasnt got crazy angles etc.
i doubt you will find anything that will bolt in and make things fit. and if you do, i doubt it will allow any kind of decent alignment
fangsport wrote:so you NEED a rwd crossmember, rack etc.......... seems obvious to me, unless you want to spend days on end designing and building something could have bad geometry.
