Where does this plug go??
Postby TRD_ZERO » Mon Jun 08, 2009 6:27 pm
Its on my blacktop, its at the back of the engine it comes off the loom at the same point as the knock sensor. Its a two wire plug.
Anyone have any ideas where it goes i just cant remember or cant seem to find it right now.
Previous:
TRD_ZERO
Postby Rick » Mon Jun 08, 2009 6:49 pm
its not the one that plugs into the gearbox?
Postby TRD_ZERO » Mon Jun 08, 2009 11:50 pm
No, i know there is two plugs that go in the gearbox one for the reverse lights and one of the speed sensor. I marked those but didnt mark this one. DAmit im not liking putting this back together there are way too many hoses and crap.
Previous:
TRD_ZERO
Postby 20v_rollaboy » Tue Jun 09, 2009 1:02 am
Maybe Map sensor?
20v_rollaboy
Postby Stu- » Tue Jun 09, 2009 11:02 am
Map usually has 3 wires. Its not an idle up or brake fluid level sensor is it? What colours are the wires?
Project Thread
Stu-
Postby TRD_ZERO » Tue Jun 09, 2009 6:42 pm
Stu- wrote: What colours are the wires?
Blue, black stripe and a black wire.
Found it, its some vaccume type sensor that i think i got told wont be getting used anymore
Previous:
TRD_ZERO
Postby matt dunn » Tue Jun 09, 2009 7:30 pm
Yeah there is a blue VSV on the underside of the ITB's.
Postby TRD_ZERO » Tue Jun 09, 2009 9:28 pm
Do i need it for forced induction?
Previous:
TRD_ZERO
Postby matt dunn » Tue Jun 09, 2009 10:40 pm
TRD_ZERO wrote:Do i need it for forced induction?
I dont even know what it does as it usually the first thing I throw away from the ITB's.
It is possibly for emission control or something, so probably not.
Postby AE25 » Fri Jun 12, 2009 2:20 am
without checking wire colours.. it sounds like the purge VSV for the charcoal can. (fuel tank vapour filter). sits under the quads with two vacuum pipes coming off the valve.
E2 & E7 fanatic
http://www.toycrazy.net
AE25
