20v VVT pully information
Postby headshotnz » Tue Jun 09, 2009 6:16 pm
Hey,
Iv searched through the forums for the 20v VVt pully problems.
My car makes a weird noise when it idles, also a "subaru" type sound when it has little oil in it.
Also at 3k revs it makes a yuck sound, and sounds like a cat being strangled from the exhaust, is this just the VVT sound.
Also whats the bad point in having a worn VVT pully, is there a performance decrease? or will it use more oil / or petrol?
Any info would be good, i havent found much searching, have searched google too, i may be using the wrong termanolodgy though.
Thanks.
Also forgot to mention i have a 91 ae101 levin, done 165k's
headshotnz
Postby Bling » Tue Jun 09, 2009 6:18 pm
I'm not going to comment on the VVT, but running any 20v low on oil is asking for trouble :(
Postby headshotnz » Thu Jun 11, 2009 3:05 am
BZG|Bling wrote:I'm not going to comment on the VVT, but running any 20v low on oil is asking for trouble :(
Thanks.
Any one got any info??
headshotnz
Postby headshotnz » Thu Jun 11, 2009 10:00 pm
surely some one most know some thing :(
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby Dell'Orto » Thu Jun 11, 2009 10:08 pm
Its pretty hard to diagnose noises over the net dude. AFAIK, the only downside with a nosiy VVT pulley is the noise, doesnt appear to make any peformance difference.
Postby Alex B » Thu Jun 11, 2009 10:08 pm
Need more info than subaru noise
ps your sig is too big with that photo, read teh rules.
Postby RS13 » Fri Jun 12, 2009 12:47 am
When my 20V pulley crapped out, it sounded like a diesel at idle.
Do the test, with your car at idle, take the plug off and apply 12V to the oil solenoid. The noise should stop.. this means that your pulley is buggered. Other than that, perhaps open the diagnostic box in the engine bay, bridge E1 and TE1, turn the key to acc (don't turn the car on) and the check engine light on the dash will flash, just hunt around on the net for the codes.
RS13
