Larger Top Feed Bosch Injectors What fits
Postby ke25sr » Mon Jun 15, 2009 10:18 am
Amazingly my dirty little boat anchor 2tg is maxing out the 3TGTEU injectors, From what i have found these are 295cc and i need bigger,
What else is a direct fit in.
ke25sr
Postby 3T-Rona » Mon Jun 15, 2009 11:07 am
i have some 4agze ones if ur interested...
PM me for anything autoelectrical, Info or jobs etc....
3T-Rona
Postby ke25sr » Mon Jun 15, 2009 11:26 am
3T-Rona wrote:i have some 4agze ones if ur interested...
I am intrested. How muchey
ke25sr
Postby ke25sr » Mon Jun 15, 2009 11:32 am
Oh and what cc are they? 365? Is the Imp differnet will i have to chage anything to use these. I no nothing...
ke25sr
Postby Guss » Mon Jun 15, 2009 6:39 pm
Judging by the other problems you've had with lack of effort ? at the tuners.
Have you checked fuel pressure ? static relief setting and pressure at max hp.
first page in google http://www.injector.com/injectorselection.php suggests that 295cc injectors should handle the power they say your making easily.
Guss
Postby ke25sr » Mon Jun 15, 2009 8:51 pm
Fuel pressure sits nicely at 45 PSI. But tuner reckons that Injectors are hitting 98% duty cycle at the moment i have to assume that he is right and he checked for other reasons for the injectors maxing out.
ke25sr
Postby 3T-Rona » Mon Jun 15, 2009 10:05 pm
$100, theyre aw11 4agze, google it to find flow rate, or i can get them flow tested and cleaned but it'll cost you extra...
what is the resistance across your 3t injectors?
ill measure the gze ones then u'll knw if u need a inj resistor or not.
3T-Rona
Postby JustinSpiderholden » Mon Jun 15, 2009 10:55 pm
Standard 3tgte are pretty much the same flow as blue tops
JustinSpiderholden
Postby gtpornstar » Mon Jun 15, 2009 11:37 pm
got some high impedance 360cc injectors top feed, just been ultrasonically cleaned. pm me if keen
Toyota Starlet GT 90
Toyota Glanza V 96
Toyota Supra N/A 94
gtpornstar
Postby drftnmaz » Tue Jun 16, 2009 2:31 pm
mazda gtx (1800) are around 365cc hi imp, top feed and you should be able to get some of these for next to nothing after that you can jump upto vr4 at 450cc but people want good money for these and i cant see a n/a 1600 really needing these
drftnmaz
Postby ke25sr » Wed Jun 17, 2009 10:48 am
So high imp means what, The 2TGEU runs a Injector resistor which i assume has something to do with this.
ke25sr
Postby 3T-Rona » Wed Jun 17, 2009 11:12 am
if it runs an injector resistor then they are low impedence, which means the resistance through the injector coil is very low and will in turn draw more current (less windings, closer to a direct short) the resistor lowers the voltage so the injector current doesnt burn out the ecu inj drive...
high and low obviously have different advantages
3T-Rona
Postby Celica RA45 » Wed Jun 17, 2009 7:35 pm
4agze 1s are 2.4 ohms and are 365 cc so should work
Celica RA45
Postby Lloyd » Wed Jun 17, 2009 7:38 pm
drftnmaz wrote: i cant see a n/a 1600 really needing these
Its a reasonably thirsty 1950-odd cc now
Postby ke25sr » Wed Jun 17, 2009 9:58 pm
Its allready used a mass amount of fuel,
ke25sr
