TRD Black Brake Pads - AE111
Postby Kittah » Mon Jun 15, 2009 1:19 pm
Hey guys,
I'm looking at the application list for TRD Black brake pads, and for AE111 it has two part numbers listed, * 04491-AEA51 and 04491-AE100. I'm just wondering if both fit, or if there's something I'm missing.
Cheers :)
Kittah
Postby MR2BOY23 » Mon Jun 15, 2009 1:39 pm
Look at the footnote....
MR2BOY23
Postby Kittah » Mon Jun 15, 2009 1:46 pm
Essdub23 wrote:Look at the footnote....
The footnotes don't apply to it. There's a note indicating what the asterisk means, above:
Attention) Brake pad "Black", which material is 3410F, is marked with "*".
But I have no idea what that means.
Kittah
Postby MR2BOY23 » Mon Jun 15, 2009 2:22 pm
Meh $200 for brake pads stuff that :P
MR2BOY23
Postby fangsport » Mon Jun 15, 2009 2:49 pm
Essdub23 wrote:Meh $200 for brake pads stuff that :P
but they are TRD ones, they will make the car go faster!!!!!
fangsport
Postby AceSniper » Mon Jun 15, 2009 2:59 pm
Think they both fit,
difference is the compound...
""Black", which material is 3410F, is marked with *"
AceSniper
Postby Kittah » Mon Jun 15, 2009 3:04 pm
I'm not paying $200 for them :P
Cheers guys, seems there's not entirely a consensus as to whether they fit. I assume they do, from the chart, though it's not totally clear I guess... I was more worried because going from ae111.co.uk only the AE100 ones fit, which seems odd, with the chart.
Doing a more in-depth Google search I've found out the 3410F bit is the material used in the pads which may or may not be suitable for certain rotors (?) but that doesn't tell me whether or not they fit :(
EDIT:
AceSniper wrote:Think they both fit,
Yeah, which makes me wonder what the difference is between them.
Kittah
Postby TRD Man » Mon Jun 15, 2009 6:51 pm
Yes they'll both fit. The difference is a heat range.
The AE100 will be fine for most applications.
TRD Man
Postby rollaholic » Mon Jun 15, 2009 6:54 pm
i used to put semi decent pads etc in my cars (lucas etc) but just recently i decided to put something really decent in a gtst skyline i had at the time. so i got some bendix ultimates, which retail for ~$200.
the difference in stopping power was incredible, i was highly impressed. will be using the same in any future street cars i own!
Postby Kittah » Mon Jun 15, 2009 10:00 pm
TRD Man wrote:Yes they'll both fit. The difference is a heat range.
Cheers for that. What's the difference in terms of heat range between the AE100 and the AEA51? I'm looking at some AEA51 pads for somewhat cheap, so I'm wondering if they're also "fine for most applications".
Kittah
Postby RAZA » Fri Jun 26, 2009 7:40 pm
Totally agree. IMO it's so worth spending a couple of hundy on a set of good pads. And some fluid. Considering how long they last the cost per km is real low. If not Bendix ultimates then one of the mintex range are good too (I'm sure the TRD ones are as well but haven't tried them myself). Last thing you want is for your cheap pads to overheat and fade and make you crash.
Currently driving:
BMW 135i M
RAZA
