RWD 20v Turbo water feed
Postby ke_25 » Tue Jun 16, 2009 4:35 pm
currenly modifying the waterpump/head to accomodate water piping and am asking what is the best possible place to run teh water feed lines for th turbo?
ihave machines the head to run as a 16v set up for water lines etc
was currently thinking of running the feed from the old outlet on the head of the 20v?
and then the return would be where the heater return is ion the 16v water lines? as i will run a Y section here i guess, although my concern is that it will be being fed from the hot part of the coolant system?
any help would be appreciated.
cheers shaun
PRESENT: KE35 Sr coupe (4agte project), GTS-T, MX40 Cressida coupe
EX:KE25 SL Coupe, KE30 4 door, KP61 4 door hatch, KE36 2 Door Wagon, AE70 2 Door Sedan, AE101 FXGT
ke_25
Postby levinguy » Tue Jun 16, 2009 10:48 pm
no idea where i would run them, but in most fwd 4agtes i've seen people don't bother running water lines, usually just oil lines for the turbo, or if they keep them they tee into the water lines going to the ISCV on the throttle body
levinguy
Postby ke_25 » Wed Jun 17, 2009 12:29 am
hey,
yeah im running a garrett 2871r so wasnt cheap so i would ratehr run the water lines, i will be running after market throttle body so thats got none of thsoe lines you were talking about as it is ae86 configuration,
thet way i was going to run it would be similer/identical to how a ae86 heater is bplumbed in? but my concern was teh ater ebing on the hot side, or isnt this going to affect it?
http://www.billzilla.org/4agwater.gif
ke_25
Postby tsoob » Wed Jun 17, 2009 11:14 am
levinguy wrote:no idea where i would run them, but in most fwd 4agtes i've seen people don't bother running water lines, usually just oil lines for the turbo, or if they keep them they tee into the water lines going to the ISCV on the throttle body
yeah that is one good option, also there is a plug that goes into the water jacket on the block
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby ke_25 » Wed Jun 17, 2009 12:36 pm
the plug into the water jacket.. is that the plug thats located next to the oil pressure take off? on th exhaust side? any one know which thread this is?
ke_25
Postby ke_25 » Wed Jun 17, 2009 12:53 pm
"coolant drain plug"?
if so which i think it is, been having a look on net would best bet be feed from here and then return into the head where radiator outlet once was?? or would this not force flow and would need to go into the back of tehr water pump where the heater is located so the pump sucks that water through??
ke_25
Postby sergei » Wed Jun 17, 2009 3:34 pm
Why not T into heater pipes (obviously before the the valve).
Postby ke_25 » Thu Jun 18, 2009 12:13 pm
could do that i guess, i was woried about if you turb the heater on it will drain? the water feed for the turbo.. but looking at it now i htink it will be fine. might run a seperate feed for the heater and turbo, and just t into the return (the one that sits on back of water pump)
ke_25
Postby tsoob » Thu Jun 18, 2009 12:53 pm
ke_25 wrote:could do that i guess, i was woried about if you turb the heater on it will drain? the water feed for the turbo.. but looking at it now i htink it will be fine. might run a seperate feed for the heater and turbo, and just t into the return (the one that sits on back of water pump)
sounds like the best option man
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby matt dunn » Thu Jun 18, 2009 1:23 pm
When we did mine we went from top radiator hose to bottom radiator hose,
as not only do you need water flowing through it when running,
but when you shut down there needs to be a way for the convection to flow water thru the turbo,
hot water rises, and so when shut down, as the turbo heats it, it flows up and out.
And I would highly reccomend NOT running a Ball Bearing turbo without water, as the plastic parts inside them do not like the heat.
Postby sergei » Thu Jun 18, 2009 4:15 pm
The problem with top and bottom radiator hoses, there is no flow unless thermostat is open, turbo can heat up a lot quicker than engine in some cases, although when it starts boiling water in the jacket there will be some movement.
Normally, factory lines run from water pump (bypassing thermostat) to turbo then it "drains" into the top hose of the radiator.
So theoretically you can T one of the heater hoses (that fed by pump) and T the top radiator hose.
Postby 4agtepwr » Fri Jun 19, 2009 11:45 am
I run mine tee'd between the heater hoses and it works fine
Current ride: Sweeeeet Hiace. 3L power!!!!
Project: AW11 4agte, 410kw 555hp on 26psi
11.1 @ 125.5mph with more to come, As seen in Aug 2011 Performance Car, haha
viewtopic.php?t=61383
Huge thanks to Phil from NZEFI, Al and Brendan from Caraid and Hamish from Sheifield Cresent Auto
4agtepwr
Postby gmacrae » Tue Jun 23, 2009 9:45 am
matt dunn wrote:...but when you shut down there needs to be a way for the convection to flow water thru the turbo,
Thats an important point for sure.
I would've thought the stock water lines that feed the throttle body or ICV/IAC would be perfect for the turbo. We dont (usually) need them on the ICV in NZ (unless you're way south)
gmacrae
Postby Akane » Tue Jun 23, 2009 11:08 am
ke_25 wrote:hey,
GT2871R is actually one of the cheaper GT Turbos offered by garret, FYI I have ran my GT2540R without water, the bearings did fail but that was because of other reasons (blocked oil drain), the turbo has been run by Matty without water for quite some time, and then onto me for a while.
my GT28RS is ran by oil only too. One of the mechanics almost screwed it up (blocking the oil drain again) but it survived.
Postby ke_25 » Tue Jun 23, 2009 11:56 am
by cheapi mean not a chinese knock off, and it was more than the 28rs also.
point is i would rather run teh water lines, hense this topic.
Cheers Shaun
ke_25
Postby Akane » Tue Jun 23, 2009 10:01 pm
as I said, you can run it without the water if you can't really get water for it, I wouldn't lose sleep over it. Just make sure you cool the turbo down properly everytime.
Postby Crampy » Tue Jun 23, 2009 10:21 pm
The way I see it is if there's water lines for a turbo, then use them. Running water can often be easier than doing the oil feed and return.
I've got water lines on my turbo GT-Z and will be doing the same on the projects I have coming up.
Crampy
Postby Akane » Wed Jun 24, 2009 1:53 am
There are times which prohabits the use of water lines. Mine is that the turbo CHRA is rotated in such a way that it interferes with the wastegate and the adaptor. A shame really.
Postby AE25 » Sat Jul 04, 2009 9:49 pm
so long as the water outlet from the turbo is connected as close to the inlet of the water pump as possible, preferably AFTER the thermostat on a 4age, in conjunction with the inlet of the turbo connected as close to the outlet of the water pump.. then you'll have best flow.
in practice this is not as easy due to the available water connection points. so unless you want to tap into the water pump housing on the front of the block to feed the turbo with cooled water.. (good luck, the cam belt runs above it!) the next best place is an outlet coming out of the engine block.. and since there are none.. (unless you want to remove the water drain from the block) :lol: next best is water outlet from the head ie original 20v radiator outlet or 16v radiator outlet or temp sensor block on back of head.
i think the main point here is that the thermostat acts like a restriction to the whole system. (like a resister is an electrical circuit) so for best water flow of an auxiliary water circuit, you need to be running in parallel with the restriction (thermostat) like the cabin heater does. (feeds from head outlet and returns after the thermostat).
unfortunately the heater circuit is taking hot water and cooling it whereas ideally you'd want to take cool water and heat it.
so in a perfect world you'd tap into the water pump housing (outlet side before it enters the block) to feed cold water to the turbo and return it into the top radiator pipe so it can be cooled before entering the engine again. but again good luck on this.. this is cam belt territory. also means every time you replace the water pump.. you have to tap into the new pump housing.. or unless you can put a fitting into the water pump backing plate on the exit side?!
soo.. unless you want to dick about modifying water pump housings.. fit the turbo feed from a water source on the head, and fit the turbo return to a line that feeds back into the water pump after the thermostat ie the heater return line or the thermostat bybass line.
in theory this is not the *best* route, but in practice, this is what factory water cooled turbo systems run. at normal operating temps, your coolant system still has enough capacity to absorb heat from the turbo before boiling point.
does this simply awesome pic kind of explain the system using rwd 16v thermostat housing with the 20v head? ... (substitute the cabin heater for your turbo)
E2 & E7 fanatic
http://www.toycrazy.net
AE25
Postby durty starlet » Sun Jul 05, 2009 8:19 pm
lol at swastika
durty starlet
