Engine swap into Hiace
Postby cat007 » Wed Jun 24, 2009 12:42 pm
Hey all
I have a 1987 Hiace (YH63) and it has a 4Y in it.
The engine runs MINT! And being a 2.2L it has a fair bit of up n go - but it's not exactly powerful.
I'm wanting something with a little more grunt - so I can tow a car (I imagine the 4Y might struggle....?)
Any suggestions for an easy engine swap?
Please don't suggest a 1UZ lol
Re: Engine swap into Hiace
Postby 1I1 » Wed Jun 24, 2009 12:48 pm
cat007 wrote:Please don't suggest a 1UZ
2UZFE? At least it'll be a bit different to the norm! :lol:
Wanting to stay toyota power? Work mate helped his uncle put a commy V6 into his Hiace, recons it goes really well (puts jet ski's in the van and on a trailer behind)
TRD Clicky >>Here
1I1
Postby cat007 » Wed Jun 24, 2009 12:51 pm
yeah - Toyota for life! lol
Was thinking a supercharged 1G hehe
Postby Adamal » Wed Jun 24, 2009 1:10 pm
Why not? Superchargers are good for towing!
Postby cat007 » Wed Jun 24, 2009 1:12 pm
Adamal wrote:Why not? Superchargers are good for towing!
Yeah I know - good low end torque - hence why I was thinking about it....
Although I'm not sure about the length of the 1G vs the van's engine bay etc....
Postby Adamal » Wed Jun 24, 2009 1:15 pm
Get one of THESE bad boys...
Postby cat007 » Wed Jun 24, 2009 1:20 pm
Adamal wrote:Get one of THESE bad boys...
Still need an engine to put it on
I was thinking a 1G-GZE as it's already done for me....
Postby fangsport » Wed Jun 24, 2009 4:14 pm
would have thought an L6 would make a tight engine bay even worse.
what about the 3.4V6 prado engine??
fangsport
Postby cat007 » Wed Jun 24, 2009 4:28 pm
fangsport wrote:would have thought an L6 would make a tight engine bay even worse.
They sound like they're late model engines - and will be pretty pricey....?
Postby fangsport » Wed Jun 24, 2009 4:40 pm
mid-90's.
shouldn't spend over 1800 to buy, and seemingly bolt up to Y, S,C bellhousing.
engine code could be 5VZ?? someone like STRX7 will know
fangsport
Postby 1I1 » Wed Jun 24, 2009 4:46 pm
fangsport wrote:mid-90's.
5VZFE out of a '96-'02 prado :wink:
TRD Clicky >>Here
1I1
Postby cat007 » Wed Jun 24, 2009 11:42 pm
hmmm
$1800 was a bit more than I was wanting to spend. Maybe I'm asking to much to not want to spend more than $800 on an engine - especially when I wont be able to just dump it in. I guess I'd need to upgrade brakes for the cert etc etc...
Postby fangsport » Wed Jun 24, 2009 11:55 pm
when there was much debate whether it should be allowed as a super/stock engine for speedway, there was talk of them being as cheap as $5-600.
another option would be an RZ engine as fitted to 96+ hiace/hilux
fangsport
Postby KwS » Thu Jun 25, 2009 12:03 am
20v 4AGE? has enough torque to spin the world off its own axis.... :lol:
Sorry, had to :P
KwS
Postby frost » Thu Jun 25, 2009 12:16 am
KwS wrote:20v 4AGE? has enough torque to spin the world off its own axis.... :lol:
Sorry, had to :P
there is a hilux single cab with one doing the rounds in chch, what a joke.
Postby Bling » Thu Jun 25, 2009 12:26 am
Jealousy works in mysterious ways 8) :lol:
Postby strx7 » Thu Jun 25, 2009 8:57 am
5vzfe with ecu and loom is definitley going to set you back around $1800-2000
Every possible engine I can think of for transplanting is later model efi and going to cost $$$
unless of course you put in a ...................... rover 3.5 v8 :? :? :?
Postby cat007 » Thu Jun 25, 2009 9:46 am
strx7 wrote:5vzfe with ecu and loom is definitley going to set you back around $1800-2000
Yeah - I guess I was being a bit daft to thing I could find an engine with decent pull to tow a car for under $800 :(
Rover V8's are a bit past it now, aren't they?
Postby cat007 » Thu Jun 25, 2009 10:39 am
fangsport wrote:when there was much debate whether it should be allowed as a super/stock engine for speedway, there was talk of them being as cheap as $5-600.
the speedway suggestion - did you mean the prado v6?
Postby fangsport » Thu Jun 25, 2009 4:14 pm
yip.much debate over whether quad-cam multi valve engines should be introduced.
i know of 2.5V6(1vz??) cheap, but not ready for removal from car yet. ordered off the road due to major structural faults.
fangsport
