1kzte dual mass clutch
Postby Redd » Mon Jun 29, 2009 3:27 pm
well after nearly a year of abuse and burnouts for africa my clutch is starting to give up the ghost. I was told yesterday the kzn165s like mine run a "dual mass clutch" which apparently mean I have to replace everything including flywheel which costs like $1200 from toyota and I'm not keen on that. Then I was told you can convert them to a standard clutch setup from an older surf with a normal flywheel but is spose to be cheaper overall has anyone done this conversion and if so how much did it cost and where did you score your parts?
Current Car : 2004 1kz Hilux
Previous Cars : 1978 Ford Escort on 15" reflexes, 1978 Vauxall Chevette powered by a 3K, 1991 ST182 Toyota Celica, 2x SW20 Turbos, 1985 R31 RB20det and an S14 ks
Redd
Postby YeMs » Mon Jun 29, 2009 6:19 pm
i havnt done it but i know aftermarket parts suppliers such as BNT/REPCO/PARTMASTER supply new conversion clutch kits for most dual mass setups including a new chromoly flywheel, clutch, pressure plate and thrust bearing.
would be worth a ring and see what they do.
also you could try ringing a commercial wrecker such as '0800 MY HIACE' and see if they will sell you a clutch and flywheel out of an early model low k wreck (long shot but worth a try). those gearboxes and easy as pie to get out so would be worth it.
Your local Hybrid Elite tech
YeMs
