How to tune a carb?
How to tune a carb?
Postby cat007 » Sun Jul 05, 2009 11:04 pm
Hey all
I'm wanting to do a bit of a basic tune up on the Hiace's 4Y.
I'm going to replace the cap, rotor and points as they're due - and then do timing.
But I'm wondering if there's anything I can do to the carb to make sure it's running right? It seems to run mint - the only thing I've noticed is, after about 2/3's throttle the accelerator stiffens up - I've always been under the impression this opens up the secondaries in the carb? Only thing is - power wise there's no change between 2/3's throttle and full throttle....
Or maybe I should just take it to a shop?
Also - it idles pretty high when warm - at about 1000-1100 but I cant seem to adjust it down enough. I think I found the idle screw - but it doesn't seem to do anything lol
Hunt
Postby 85AW20v » Sun Jul 05, 2009 11:10 pm
With the high idle, it might have a waxstat type of thing like the 4A's do that give trouble - or a vacuum leak somewhere.
See ya
Simon
85 MR2 20v
85AW20v
Postby cat007 » Sun Jul 05, 2009 11:15 pm
Simon85MR220v wrote:With the high idle, it might have a waxstat type of thing like the 4A's do that give trouble - or a vacuum leak somewhere.
Hmmm - I'll look into it
wait
what's a waxstat? LOL
Postby 79rolla » Mon Jul 06, 2009 1:07 pm
also look at replacing the condensor? its what i alwase forget lol
past: AE82 FXGT
79rolla
Postby cat007 » Mon Jul 06, 2009 1:12 pm
Ah yeah. That's the little capacitor type thing that hangs off the dizzy?
Postby MAGN1T » Mon Jul 06, 2009 11:16 pm
Auto chokes often play up and make it idle too fast.
Steve
Computers make you go mad.
MAGN1T
!USER HAS BEEN BANNED!
Postby cat007 » Tue Jul 07, 2009 8:22 am
Funny you mention auto chokes because this morning the auto choke wouldn't come on. I don't know what I did lol
Postby nivaman » Tue Jul 07, 2009 2:50 pm
cat007 wrote:Funny you mention auto chokes because this morning the auto choke wouldn't come on. I don't know what I did lol
Touched it :lol: .
nivaman
Postby cat007 » Tue Jul 07, 2009 2:54 pm
Touched it :lol: .
hahah yeah - pretty much!
I did adjust what I thought was the idle screw. It seems to have helped - now it idles much lower, in fact it might be a bit too low now!
But the choke doesn't seem to come up dammit
I'll have to have a play tonight.
How does the auto choke work? How can I force it/trick it into thinking it needs the choke on?
Postby MAGN1T » Tue Jul 07, 2009 5:29 pm
You probably need to reverse the last thing you did to it.
Steve
MAGN1T
