does anyone have any specs for gen2 3sge and/or 3sgte cams??
iOnic wrote:Gen 3 uses a shim under bucket setup so to use Gen3 cams in a Gen 2 you need to convert to shim under bucket or go shimless altogether by using MR-S shimless buckets (good thing to have on the to-do list if you're after revs).
fivebob wrote:While I agree that under-bucket shims are better you don't have to do that just because you use a Gen III cam.
iOnic wrote:fivebob wrote:While I agree that under-bucket shims are better you don't have to do that just because you use a Gen III cam.
Really? Can Gen3 cams be used in the Gen2 head without changing the shim/bucket setup? That's really good info to know if so
iOnic wrote:Gen2
3SGE (165ps):
In: 244deg, 8.5mm lift
Ex: 244deg, 8.5mm lift
3SGTE (225ps):
In: 236deg, 8.2mm lift
Ex: 236deg, 8.2mm lift
Gen3
3SGE A/T (170ps):
In: 240deg, 8.7mm lift
Ex: 240deg, 8.2mm lift
3SGE M/T (180ps):
In: 252deg, 9.8mm lift
3SGTE (245ps):
Gen 3 uses a shim under bucket setup so to use Gen3 cams in a Gen 2 you need to convert to shim under bucket or go shimless altogether by using MR-S shimless buckets (good thing to have on the to-do list if you're after revs). You can't use Gen1 (ST165) cams in later heads - they are a different setup altogether (later cams have better specs anyway)
