the fallen303 wrote:6pk1865, 1865mm belt. gates part number K060735. did this to my in my supra.
FLAWLES wrote:the fallen303 wrote:6pk1865, 1865mm belt. gates part number K060735. did this to my in my supra.
ha
was going to ask you this in the weekend
guess i dont have to now
also
im 100% sure the 2jz water pump pulley is diff and the rest are the same? or do i have that the other way around
YeMs wrote:FLAWLES wrote:the fallen303 wrote:6pk1865, 1865mm belt. gates part number K060735. did this to my in my supra.
ha
also
yeh but people generally do the 1jz waterpump conversion (like i have) to get rid of the hydraulic fan pump.
FLAWLES wrote:YeMs wrote:FLAWLES wrote:the fallen303 wrote:6pk1865, 1865mm belt. gates part number K060735. did this to my in my supra.
ha
also
explane?
water pump converson
the fallen303 wrote:last time we priced up a replacement hydro pump was over $1500, bout 5 years ago. not fun. plus custom turbo intake pipes went straight through where the hydro pump sat...
ryanfels wrote:the fallen303 wrote:last time we priced up a replacement hydro pump was over $1500, bout 5 years ago. not fun. plus custom turbo intake pipes went straight through where the hydro pump sat...
Awsome, i was just going to ask why people change it. So when changing to the mechanical 1, you have to change the pulley and run a 1jz powersteering pump?
