Car cutting out
Car cutting out
Postby method » Fri Jul 17, 2009 6:10 pm
I have a strange problem with my 4age turbo at the moment.
Every now and then, more often now than before, the car cuts out when i back off the throttle.
Say im at accelarating at 3/4 throttle and back off to only 1/2 throttle most cars would simply stop accelarating as quickly. My car sometimes will cut out for a second or two then power would come back on as 1/2 throttle as if i had gone from 3/4 throttle down to 0 throttle quickly then back up to 1/2 throttle. As you can imagine it gives you a bit of a jolt.
It also sounds as if i had fully backed off the throttle, the engine just cuts power for a second.
Car is a 4age turbo, running standard 4agze fuel pressure and a 4agze computer, CAS, ignition etc.
any ideas?
Thanks!
PICS UPDATED DAILY
method
Postby iOnic » Fri Jul 17, 2009 6:18 pm
TPS?
Postby MrOizo » Fri Jul 17, 2009 7:43 pm
The enigne isnt rocking and knocking wiring is it?
MrOizo
Toyspeed Legend
Postby method » Fri Jul 17, 2009 8:08 pm
Could well be Mr Ozio.
Ill check and make sure its not pulling on any sensors. How would i check the TPS?
But it does it when i go from like 1/4 throttle to 1/5 throttle. So only light accelaration.
I just ran the diagnostics and it threw up 21 and 22.
21 is O2 sensor. I guess it is because i'm not running one.
22 is water sensor. Could this be affecting it? I know it has something to do with the fuel maps doesn't it.
Club 4AGE also lists vaccume sensor as a common problem when 21 is throwen up. 31 is vaccume sensor but its not throwing that up so i guess it is ok?
Car runs fine apart from this stuttering.
PICS UPDATED DAILY
method
Postby l1ttle_d3vil » Fri Jul 17, 2009 9:19 pm
method wrote:Ill check and make sure its not pulling on any sensors. How would i check the TPS?
I would be checking the TPS first. Get a multimeter and feeler gauges and check the resistence at certain throttle, the specs are in the FAQs on here.
Water sensor just tells the ECU what temp the engine is, wouldn't think it should cause a stuttering as severe as what you describe, but worth checking out if the TPS doesn't come up faulty.
Postby crispy'86 » Sat Jul 18, 2009 9:11 am
Yip check the tps, someone else on here had a similar problem with their ae101 s/c and that was a tps fault. That particular one on closer inspection turned out to have water inside the tps
crispy'86
Postby 1hypo3 » Sat Jul 18, 2009 9:15 pm
The water sensor effects the fuel if its open circuit it will run quite rich, its a negative temp coefficent so as temp rises resistance decreases so put it in a pot and warm the water up and use a multimeter and check the resistance
code 21 could be from the 22 code been output
1hypo3
Postby shazeal » Sat Jul 18, 2009 10:24 pm
My GZE was doing same thing, was the water temp sensor.
Current - 83 Levin AE85 Notch.
Ex - 89 Sprinter - Red Top, 88 Levin - 4agze.
shazeal
Postby method » Sat Jul 18, 2009 11:16 pm
Cool thanks a lot for the help guys. Will put new water temp sensor in tomorrow and report back with if it worked or not.
Have checked TPS and made sure it is adjusted right. Seems to be all ok.
PICS UPDATED DAILY
method
