vista/camry gear shift lock
Postby l3_vin » Sat Aug 01, 2009 3:09 pm
hey i have a 1992 vista/ camry auto. the gear shift lock does not disengage when i press foot brake. so i have to use the red button on the side. Also the head unit does not work. I have checked all the fuses in engine bay and ignition fuses on drivers side. Also had a quick look at wires to head unit and everything seems fine.
What could the problem be? it may be two separate problems?
l3_vin
Postby Dragger_Dan » Sat Aug 01, 2009 3:56 pm
I've driven three different camrys with that exact same problem. No idea what it is tho sorry.
Dragger_Dan
Postby Lloyd » Sat Aug 01, 2009 4:36 pm
Brake light switch or solenoid in the shifter at a guess.
Postby l3_vin » Sat Aug 01, 2009 9:09 pm
so head unit probably not linked?
l3_vin
Postby B0000M » Sun Aug 02, 2009 8:34 am
most likely not.
do your brake lights work?
B0000M
Postby l3_vin » Wed Aug 05, 2009 8:26 pm
yeah they did work. lead me to believe it was a disconnected wire etc?
anywho car is sold, and new owned didn't mind the problem. cheers
l3_vin
