I'm hoping you guys might be able to point me in the right direction-
I need to upgrade my clutch, I currently got a SJ Suzuki with toyota running gear, Hilux transmission and a gen2 3sge, The std clutch starts to slip after a dunking in the mud and slit. I'm after a hd clutch, I've got a 3sgte which I want to fit next season, will the pressure plate (gte) have a higher clamping force than the ge, and will it fit?
Cheers Chris
