Oil filter adaptor bolt...where to get a longer one?
Postby XSVWGN » Wed Aug 12, 2009 10:43 pm
Have spent the day going around wellington looking for a longer fitting. I went to 3 plumbing places and wellington biggest supplier/producer of brass fittings with no luck. The dillema i have is that the current one is about 5mm short to screw my adaptor plate from the remote oil filter relocator
Here are a few pics of the current item. Any one know of somewhere i can get one of these but longer without going to an engineer?
Matt
2008 Kia rio - work car
XSVWGN
Postby Bazda » Wed Aug 12, 2009 11:17 pm
might help if you tell us the thread size and type.
Postby XSVWGN » Wed Aug 12, 2009 11:18 pm
i would if i could mate. was told it may be an 18mm size and thread maybe Mx 1.125 or something...
Thats all i know
XSVWGN
Postby levinguy » Wed Aug 12, 2009 11:20 pm
if you have the right size fitting but just need a longer one, surely some local place could order one in?
levinguy
Postby XSVWGN » Wed Aug 12, 2009 11:22 pm
I went to a couple of places and they said the one i had was the largest size they couple get. Thought there must be somewhere else in nz (especially Auckland) that would have one
Matt
XSVWGN
Postby fivebob » Wed Aug 12, 2009 11:56 pm
What's it from?
Most Toyota oil filters are 3/4"x16tpi (UNF) thread.
Postby XSVWGN » Thu Aug 13, 2009 12:12 am
its from a ae92 4agze block
XSVWGN
Postby thegreatestben » Thu Aug 13, 2009 12:16 am
thegreatestben
Postby XSVWGN » Thu Aug 13, 2009 12:23 am
probmel being is that no one in welly has any. does anyone know if any other toyota ones are longer? may just have to do some pick a part missions...
XSVWGN
Postby fivebob » Thu Aug 13, 2009 12:30 am
The next question is are both sides exactly the same? Looks to me like the shoulder where the thread terminates is different on each end.
Could you use something like an adaptor the bolts on to the existing connector to extend it?
Postby XSVWGN » Thu Aug 13, 2009 12:31 am
thread is the same on both sides. Went through adaptors etc today...nothing fit
XSVWGN
Postby fivebob » Thu Aug 13, 2009 12:40 am
Then I suggest you go to an engineer as I doub't you'll find anything that will meet your needs off the shelf. They could make one up quite easily and it shouldn't cost that much.
Postby XSVWGN » Thu Aug 13, 2009 12:43 am
fivebob wrote:Then I suggest you go to an engineer as I doub't you'll find anything that will meet your needs off the shelf. They could make one up quite easily and it shouldn't cost that much.
yea thats what im debating at the moment. could buy a plate from trademe which would be exactly what im after but thats $69 so may aswell just a new threaded piece fabricated
Matt
XSVWGN
Postby mr30%jr » Thu Aug 13, 2009 12:51 am
threaded brass pipe braise a bit in the middle lol to assist tightning
mr30%jr
Postby fivebob » Thu Aug 13, 2009 12:56 am
Don't use brass pipe if you want it to hold together, brass will fracture from the vibration. It needs to be steel.
Postby XSVWGN » Thu Aug 13, 2009 12:58 am
fivebob wrote:Don't use brass pipe if you want it to hold together, brass will fracture from the vibration. It needs to be steel.
isnt the standard one brass? been in the engine i took it out of for 15 years and hasnt cracked or been damaged yet...
XSVWGN
Postby fivebob » Thu Aug 13, 2009 1:00 am
Not that I've ever seen, and the colour of the photo suggests it's steel with baked on oil discolouration. Try a magnet on it to check.
Postby XSVWGN » Thu Aug 13, 2009 1:02 am
magnet sticks to it. Just used a fridge magnet so its pretty weak but it works 8)
XSVWGN
Postby thegreatestben » Thu Aug 13, 2009 1:10 am
seem to remember a 1ggte having alonger one due to having an oil cooler between the block and filter.
Not sure if same thread though
thegreatestben
Postby frost » Thu Aug 13, 2009 1:23 am
thegreatestben wrote:seem to remember a 1ggte having alonger one due to having an oil cooler between the block and filter.
if there the same as mr2 style oil cooler blocks it will have a one sided thread not double. same to 20v ones.
