Ignition fuse blows contiously
Postby gleem » Sun Aug 16, 2009 3:18 pm
Wired up a wasted spark set up on my rb20det, When i first tried engine cranked over fine but didnt start and then the one of the wires stared to melt on the 3 wire plug, so replaced the wire and it still wont start, every time i turn key to start the ignition fuse blows, gone through 6 fuses now. anyone on here familiar with these rb setups?
gleem
Postby Mr Revhead » Sun Aug 16, 2009 3:23 pm
that would suggest to me that you have a fault in there somewhere :P
Postby nz_climber » Sun Aug 16, 2009 5:28 pm
Find the short in the wiring loom is the only option.. You will just melt more wires if you don't find the cause of the problem
nz_climber
Re: Ignition fuse blows contiously
Postby Trls250s » Sun Aug 16, 2009 5:41 pm
gleem wrote:Wired up a wasted spark set up on my rb20det, When i first tried engine cranked over fine but didnt start and then the one of the wires stared to melt on the 3 wire plug, so replaced the wire and it still wont start, every time i turn key to start the ignition fuse blows, gone through 6 fuses now. anyone on here familiar with these rb setups?
There is a short between a power feed and ground, or you have made a ground live. Check your wiring and see if you have put power to a ground or a ground to a power.
Replacing wires over and over again will not fix the problem.
4a-ge noun for-ay-gee
1600cc of Awesome
AE86 noun aye-ee-ate-six
Rusty Corolla
www.GARAGEDORI.com
Trls250s
Postby matt dunn » Sun Aug 16, 2009 7:01 pm
If one of the wires melted you have wired something up wrong,
and probably buggered something.
Unplug it all and put a fuse back in and then plug stuff back in and see what thing you plug in makes the fuse blow.
And How have you wired it up?
where do the 3 wires in the 3 wire plug go?
