fukt clutch & fly wheel
Postby Infinite » Wed Aug 19, 2009 7:27 pm
Clutch is nearly 5 thousand k's old!. this is also a evo 5 but would like some opinions from everyone!
i only have a pick of this side and clutch plate is currently being checked for tru-ness in auckland. as u can see the wear on the plate is un-evan... other side is worse!!!....
On the pressure plate on the top left section u can see a "launch" mark yet I! havent launched it... u can actuley feel the imprefection on the pressure plate aswell....
my flywheel!!!! "aparently it was machined" on a lathe not a mill.. looks good in the photo realy... compared to in person...
Basicly what do u people think??? what could cause this in under 5 thousand k's of driving????. The car gets driven not thrashed its not reved over 5.5k its runing 12psi.. I have one big bill for a new exeedy oe clutch and one fukt clutch to show for it... not to mention 8 months of problems thats been put down to a fukt clutch... Personaly i beleave the flywheel hasnt been machined and its eatn the clutch? or hasnt been machined smooth!
Lots
Infinite
Postby Mr Revhead » Wed Aug 19, 2009 7:55 pm
who installed it?
did they put the plate in the wrong way?
was the previous clutch really rooted? ie to score the flywheel?
Postby Infinite » Wed Aug 19, 2009 8:04 pm
a mitsi workshop did the work. no the plate was in the right way dont think they can go in backwards??? last clutch was warn and seen the box was out did it... had about 2 hot spots on the flywheel
Lots
Infinite
Postby strx7 » Wed Aug 19, 2009 8:13 pm
looks like the flywheel surface wasnt true.
It should have been milled on a clyinder head type bed.
Postby Dell'Orto » Wed Aug 19, 2009 8:31 pm
Bent clutch plate or the flywheel is out of true maybe
Postby Mr Revhead » Wed Aug 19, 2009 8:32 pm
Infinite wrote:a mitsi workshop did the work. no the plate was in the right way dont think they can go in backwards??? last clutch was warn and seen the box was out did it... had about 2 hot spots on the flywheel
no idea on those, some can and have heard of that
or another thing is the clip not on the thrust bearing properly :oops:
ended up like the above as the clutch was never fully disengaged but never dragged enough to be picked up until clutch failed in a very short distance
that would also depend on the design though
Postby Infinite » Wed Aug 19, 2009 8:37 pm
ok thank u for opinions, its a pull type clutch
Lots
Infinite
Postby Infinite » Thu Aug 20, 2009 3:59 pm
also if i was "dumping" the clutch as ive been told thats what im doing and thrashing the ass off it!. wouldnt the pressure plate have alot of marks on it aswell? not just a burnt to hell flywheel with heaps of hot spots? and wouldnt the hot spots be on the pressure plate aswell?
Lots
Infinite
