20v 4rage turbo
20v 4rage turbo
Postby KwS » Sun Sep 27, 2009 8:58 pm
Hello
Ive done a lot of research on this now, and im starting to write up plans and get parts together, to turbo my silvertop. Ive got a couple of questions though, that i cant really find a simple answer to.
First off, this is a real simple one.... The turbo oil drain and feed. I assume oil drain is into sump, and iirc it needed to be above oil level? And where is it best to get the oil feed from? Could i get it from say, a sandwich plate on the filter? Or is there an easy way to get it from the block or head?
Ive read the plenum cant hold pressure, is that correct? Ive budgeted for replacing it, but in the early stages it would be nice to be able to use the standard one.
I know most people that turbo 4ages usually do the ZE, which has an ecu that can obviously cope with boost. What do 20v peoples usually do in regards to an ECU? i want to go link eventually, but thats a while off. Will the silvertop ecu handle boost? If so, how much?
Whats a reasonably safe boost to run on an unopened silvertop? 5psi? I do plan on building up a forged engine while running this one, but dont want it to die too quick. The AFRs will be checked with my mates fancy innovate wideband to make sure im not leaning out.
Once again, at those sort of boost levels, how will the stock injectors cope? Best to upgrade them?
KwS
Postby tsoob » Sun Sep 27, 2009 9:36 pm
hey man what is your budget? based on that it will be eaiser to recomend what route to take.
oil feed off the block is common.
You will need some kind of intake plenum made.
What bottom end are you going to run?
really first things first what can you afford to spend?
Link g4 would be ideal :)
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Adoom » Sun Sep 27, 2009 9:37 pm
I can answer two of your questions....
The oil drain has to end above the oil level, or the oil will back up in the pipe stopping it from draining.
My factory(CA18ET) turbo oil supply is from a T-Piece where the oil pressure sensor screws into the block.
Adoom
Postby thegreatestben » Sun Sep 27, 2009 9:42 pm
Have the same setup on my 7a, t piece into the block with oil pressure sensor.
thegreatestben
Re: 20v 4rage turbo
Postby matt dunn » Sun Sep 27, 2009 9:53 pm
KwS wrote:I know most people that turbo 4ages usually do the ZE, which has an ecu that can obviously cope with boost. What do 20v peoples usually do in regards to an ECU? i want to go link eventually, but thats a while off. Will the silvertop ecu handle boost? If so, how much?
The standard one will not do boost.
There is a Megasquirt option on here that may be of some use,
but if the goal is link in the end, then your better to do that first up.
KwS wrote:Whats a reasonably safe boost to run on an unopened silvertop? 5psi? I do plan on building up a forged engine while running this one, but dont want it to die too quick. The AFRs will be checked with my mates fancy innovate wideband to make sure im not leaning out.
As long as you have an intercooler and a good tune,
you can run reasonable levels.
I am sure that I know of one that was at 15psi on stock stuff,
but 5 to 8 would probably be more acceptable.
KwS wrote:Once again, at those sort of boost levels, how will the stock injectors cope? Best to upgrade them?
Yup to upgrade, but they may take a few psi of boost,
but therer are heaps of injectors that are better at around the 250-300 a set mark.
Turbo MR2 and GT4, early 1JZGTE and 2JZGTE.
all around 380 to 480ish over the 295cc??( i think) stock ones.
Postby gasman » Sun Sep 27, 2009 10:15 pm
i got a plenum you can buy that will hold up to 32psi
"What can possibly go wrong?"
gasman
Postby KwS » Sun Sep 27, 2009 11:05 pm
ive worked out itll cost about 2500 all up for all the bits, and ill be doing the work myself. That doesnt factor in an ecu though.... which is bit of an ass, having to replace that straight up. Im not really too sure what my budget has to do with the questions i asked though.
Ill be getting everything bit by bit, as i go along. If i need to upgrade other things, then ill wait till i have those parts before putting it all together.
I intend to run a subaru legacy water to air intercooler setup. Should keep intake charge plenty cold for what i intend to do.
I assume the engine already has a oil pressure sender on it somwhere, for the idiot light. Could i remove that and add a T there for the feed?
Ive looked on the link site, and i cant seem to find one... so i assume it doesnt exist, but has anyone seen a plug-in G4 for an ae101?
KwS
Postby KwS » Sun Sep 27, 2009 11:07 pm
gasman wrote:i got a plenum you can buy that will hold up to 32psi
I would love that plenum, but at this point in time i cant really afford it. Ill keep an eye out for when i have more money and might be in touch. I assume that'll work with the silvertop ITBs and trumpets etc (as i see its on a blacktop head)? I could probably run that plenum NA.... just for bling factor :P
KwS
Postby molex » Sun Sep 27, 2009 11:35 pm
Have a look at This
Plug and play (as in you don't have to modify your loom) and has all the features you'll be wanting for a pretty awesome price. $650 shipped.
Bit easier to swallow than ~1500 for a link G4 and loom.
Any reason you're going for the wta setup over a much less complicated front mount air to air setup?
molex
Postby ChaosAD » Mon Sep 28, 2009 12:02 am
molex wrote:Have a look at This
Ive got one of those sitting here.
The pin count is right for the silvertop, but the pin sizes are different on the silvertop dash plug so it wont fit.
Plugs up to the blacktop alright though.
Also allow for gst incase it doesnt slip through customs as it is over $400NZ.
ChaosAD
Postby tsoob » Mon Sep 28, 2009 12:18 am
KwS wrote: Im not really too sure what my budget has to do with the questions i asked though.
based on your budget you can make the decisions on what is most important. What kind of power do you hope to make?
if you were to spend the 2500 + the cost of an ecu and tune you should end up in the 140-160 kw wheels range without too much difficulty if you can do plent of the work yourself and don't take 2 many short cuts.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
tsoob
Postby mr30%jr » Mon Sep 28, 2009 8:27 am
ive heard silvertop ecus cope with boost fine as they are AFM, just up the injector size. depends on how rangi you wanna be i suppose too bad wayne hates toyspeed he really is pretty knowedgeable on 4agtes and how to do them REALLY cheap
mr30%jr
Postby MR2BOY23 » Mon Sep 28, 2009 9:09 am
What turbo are you planning to use?
MR2BOY23
Postby rollaholic » Mon Sep 28, 2009 10:09 am
i think wayne is actually banned from TS also :lol:
Postby KwS » Mon Sep 28, 2009 9:03 pm
i'd be happy with 150fwkw.
I intend to use a t3/t4 as the manifold i can get has that flange, and i can get hold of those turbos cheap.
I want to do this without spending too much over 2500 ideally. Needing to replace the ecu before i can do anyhting is rather limiting for me.
KwS
Postby Flannelman » Tue Sep 29, 2009 8:12 pm
i would suggest if you are going to build a stunner turbo motor later, then start now. save up, build the motor you want as you go. trying to create a cheap bits'er is asking for trouble.
if it was cheap and easy to do, then everyone would have one
Flannelman
formerly known as Affroman
Postby KwS » Tue Sep 29, 2009 9:41 pm
what i was planning on doing was building this up cheaply, as it is and when when the forged engine is built, transfer all the turbo stuff over to the new engine. So, i would still be using all the parts from now, but would make better use of them (higher boost).
Im going to put some more thought into it and get my maths on, and work out if its really that feasible for what is essentially a hyped up econobox... or just sell corolla and get something thats turbo to start with.
KwS
