KwS wrote:I know most people that turbo 4ages usually do the ZE, which has an ecu that can obviously cope with boost. What do 20v peoples usually do in regards to an ECU? i want to go link eventually, but thats a while off. Will the silvertop ecu handle boost? If so, how much?
KwS wrote:Whats a reasonably safe boost to run on an unopened silvertop? 5psi? I do plan on building up a forged engine while running this one, but dont want it to die too quick. The AFRs will be checked with my mates fancy innovate wideband to make sure im not leaning out.
KwS wrote:Once again, at those sort of boost levels, how will the stock injectors cope? Best to upgrade them?
gasman wrote:i got a plenum you can buy that will hold up to 32psi
molex wrote:Have a look at This
Plug and play (as in you don't have to modify your loom) and has all the features you'll be wanting for a pretty awesome price. $650 shipped.
Bit easier to swallow than ~1500 for a link G4 and loom.
Any reason you're going for the wta setup over a much less complicated front mount air to air setup?
KwS wrote: Im not really too sure what my budget has to do with the questions i asked though.
