ae101 starter motor fuse? engine won't crank
Postby levinguy » Thu Oct 01, 2009 8:22 pm
hey all
cant get my silvertop cranking in my levin, was working fine, took off my intake plenum and now it wont crank
i get 12 volts constant to the starter motor, but the exciter wire doesn't give 12 volts when the key is turned.
before i pull my loom out, is there a fuse for this wire between the ignition barrel and the starter motor? iv checked all the fuses i can find (engine bay box and right hand drivers side) and they are sweet.
most likely to be a break in the wire somewhere?
Rob
levinguy
Postby mr30%jr » Thu Oct 01, 2009 8:47 pm
theres only a starter relay.
its not auto is it?
mr30%jr
Postby levinguy » Thu Oct 01, 2009 9:36 pm
mr30%jr wrote:theres only a starter relay.
its not auto is it?
didnt think of that,
it was auto, but converted to manual, only just got it and don't know alot about it
isnt there a plug which needs to be earthed or bridged? could be what i was looking for! where abouts would it be?
thanks!!
levinguy
Postby levinguy » Fri Oct 02, 2009 10:04 am
was the inhibitor plug thing.. was done dodgy before
cheers!
levinguy
What is this?
Postby slowtravel » Fri Nov 20, 2009 1:40 pm
levinguy wrote:was the inhibitor plug thing.. was done dodgy before
cheers!
What's this thingee, please?
I too have an (intermittent) fault where the starter won't crank though the dashboard lights are fine, and there's not even a click when turning the key.
Try it in a minute and it starts up!
My wife did something I'd not ever thought of doing, turn the key and LEAVE IT TURNED. After a few secs the started worked!
Is this the ign barrel, the whole key assbly, a sticky solenoid, or your inhibitor plug thingee?
Brian
Spacio AE111
slowtravel
Re: What is this?
Postby matt dunn » Fri Nov 20, 2009 11:03 pm
That is normally a sign of voltage drop.
Try the headlights rear demister and heater on and then try to start.
If it makes it worse it needs a starter relay.
Some cars had them factory? Which model is yours?
