Fuel Lines, carby to efi
Postby 20v_rollaboy » Mon Oct 05, 2009 6:16 pm
Possibly getting a 2e powered Corolla. Just need to know if i can just add the fuel return line or have to replace all lines. Anyone know if the fuel pump assembly will directly replace the carby setup?
20v_rollaboy
Postby xsspeed » Mon Oct 05, 2009 6:18 pm
you will need a return line + efi fuel tank + fuel filters etc.
easiest option may be to remove lines, filters, tank and pump from pickapart/or buy a fxgt wreck - this is what I did
Postby 20v_rollaboy » Mon Oct 05, 2009 6:25 pm
Didnt realise whole tank needed replacing 8O
Do you know if the lines are the same length between the 4 door and 2 door models?
20v_rollaboy
Postby XSVWGN » Mon Oct 05, 2009 6:25 pm
oooooooooooooooooooor buy an fxgt ;)
2008 Kia rio - work car
XSVWGN
Postby rollaholic » Mon Oct 05, 2009 6:26 pm
what engine are you planning to put in it?
you will need to sort out a return, but you could also plonk an external somewhere to avoid the in tank pump hassles
Postby 20v_rollaboy » Mon Oct 05, 2009 6:31 pm
Either a 4a or 4e, most likely the latter because I have one in my garage allready.
External pump might be an idea :idea:
20v_rollaboy
Postby 20v_rollaboy » Mon Oct 05, 2009 6:32 pm
XSVWGN wrote:oooooooooooooooooooor buy an fxgt ;)
People want too much for them :!:
20v_rollaboy
Postby XSVWGN » Mon Oct 05, 2009 6:44 pm
haha yea they do aye...4000plus normally even with 250,000kms on the clock!
XSVWGN
Postby xsspeed » Mon Oct 05, 2009 6:53 pm
been a few lately for 300 or less, just gotta keep an eye out.
Tank is different, though could possibly just put pump into carb tank - wouldn't have baffles though I'd say.
5efhe?
Postby ee904age » Mon Oct 05, 2009 7:08 pm
My ee90 alread had two lines running from the tank to the engine bay. I just used them for the feed and return. I had it running but never drove it due to gearbox issues. I then put the motor into a carbed AE82 using the same two lines as before and the std tank with an external pump mounted under the car. The only issue I had was a few surge problems when under 1/4 tank on hard/high speed cornering. I had plans to put in a surge tank but sold the car before installing it.
I vote go for the 4E, because A. you already have it, and B. you dont need to change any mounts.
90 SW20 Turbo - Project
90 SW20 N/A - Sold
ee904age
Postby postfach » Tue Oct 06, 2009 10:20 am
If you're going to use existing lines you should replace the soft lines with efi hose, factory stuff might be low pressure.
postfach
Postby rollaholic » Tue Oct 06, 2009 1:11 pm
it will be low pressure,
but on my AE85 whoever did the 4age conversion just used factory setup from carbed engine and put external in the engine bay, thereby minimising the amount of line that was pressurised by the pump (EFI hose is pretty expensive)
was bit noisy tho
it was all pretty rangi but pretty much the only part of the car that didnt give me some kind of issue while i owned it
Postby AceSniper » Tue Oct 06, 2009 2:02 pm
the two carb lines ones a fuel line and ones for tank vent is it not? so if using both lines for efi you will need a new tank vent setup?
AceSniper
Postby 20v_rollaboy » Tue Oct 06, 2009 4:22 pm
Thanks for all the replies guys, Im going to look for a complete efi tank and lines, looks to be the easiest option.
Anyone know if the overall length of the 2 door and 4 door models are the same? Or even if the tank is in the same position or the lines are the same length?
20v_rollaboy
Postby xsspeed » Tue Oct 06, 2009 4:25 pm
yep all the same from what I have done so far on mine
wreck
Postby fxgt race » Tue Oct 06, 2009 5:18 pm
I have a fxgt wreck here , mt wellington, you can take the tank and all lines needed for $80. Or I have a tank all ready out,The pump is uprated and nearly new as i ran it on the race car before i changed to a plastic tank, After $100 for the pump setup so $180 for all parts with the pump.
Pukekohe 1.07.6
Taupo 1.41.3
Manfield 1.18.7
hamptondowns 1.15.2
fxgt race
Postby ee904age » Tue Oct 06, 2009 5:46 pm
AceSniper wrote:the two carb lines ones a fuel line and ones for tank vent is it not? so if using both lines for efi you will need a new tank vent setup?
I think so, as one of the lines just went to a filter/vacuum arrangement before I stripped it out. The cap had a vent anyway so no major.
Also I dont reccomend putting an external in the engine bay as I was told 'sucking' fuel up from the tank will shorten their lifespan, so try and keep it at or below the fuel level.
90 SW20 N/A - Sold
ee904age
Postby gasman » Wed Oct 07, 2009 8:27 am
When I did a carb to efi conversion on my first AE92 I ghad bought the whole tank but realized I only needed the pump with the mount assembly that screws onto the fueltank with about 10 screws or so. And also the efi fuel line and filter.. everything clipped and screwed into place. There was also a return line from the carb back to the fuel tank and also a vent from the fuel tank to the engine bay where it went into a small canister thing.
"What can possibly go wrong?"
gasman
