5efte not starting - help
Postby sik_gt_starly » Wed Oct 07, 2009 9:02 pm
put this on starletcentral but no answer yet:
car - ep82 starlet
motor - 5efhe long block with 4efte running gear ecu injectors etc, with big turbo and a few other things. purchased from dodsons a year ago with 80,000km on clock
everything is together and plugged in/bolted up etc, motor is turning over sweet as, has oil and water
is making spark and firing order is correct
pretty sure its getting fuel as when turning over can smell unburnt petrol coming out of the downpipe (isnt connected up to exhaust yet)
can hear it making compression in all 4 cylanders however havnt done compression test
havnt touched motor since getting it from dodsons, only put new plugs in.
any help as to why its not going?
if you need more info sing out.
thanks alot
sik_gt_starly
Postby l1ttle_d3vil » Thu Oct 08, 2009 8:45 am
timing?
Postby sik_gt_starly » Thu Oct 08, 2009 1:25 pm
pretty sure it has to be the timing, thats all thats really left that could be causing it to not start.
will try a few things tonight and see if any luck.
another option was maybe fuel is old
its not even spluttering or anything trying to start, just turning over
sik_gt_starly
Postby 79rolla » Thu Oct 08, 2009 1:32 pm
try engin start or something.. if still does notheing or backfiers werd it will be timing, get the motor to TDC and cheack everything over
past: AE82 FXGT
79rolla
Postby l1ttle_d3vil » Thu Oct 08, 2009 6:00 pm
sik_gt_starly wrote:its not even spluttering or anything trying to start, just turning over
wrong timing could cause that, if you've got fuel / compression / spark. try engine start as said above just to eliminate fuel for sure, should atleast fire once or twice on engine start alone.
haven't got the timing 180º out have you?
Postby sik_gt_starly » Thu Oct 08, 2009 6:44 pm
stuck some engine start in there, after a bit more just turning over burst into life. coolant n oil heating up idles sweet took for a wee drive, success its going!!!! soooo stoked
will post up pics etc once i finished mucking round with car
sik_gt_starly
Postby l1ttle_d3vil » Thu Oct 08, 2009 6:55 pm
maybe your cold start isn't working properly then? see what its like next time its dead cold in the morning or something.
