rust in boot gutter wof fail?
Postby jakesae101 » Fri Oct 09, 2009 8:00 pm
ok so my trueno went for its for a week or so ago i fexed all the other issues he had with the car (failed on cracks in the top hats and needed new front hoses ) but he failed me on rust on the boot gutter its where the rubber sits over the car is 21 years old now so its expected some rust he picked up what he thaught was a hole but it was a 2mm pit in the metal that i sanded back and painted over but it was my undertsanding that the boot gutter wasnt a wof fail issue am i correct here
EX. MK2 escort 4 door 1300cc
EX. AE101 trueno gt apex
jakesae101
Postby ChaosAD » Fri Oct 09, 2009 8:19 pm
http://www.ltsa.govt.nz/certifiers/virm-in-service/general-03-v3a5.pdf
I CBF reading through it, but your answer should be in there somewhere. Depends how close it is to the top of the A pillar I believe
ChaosAD
Postby jakesae101 » Fri Oct 09, 2009 8:29 pm
well thats the thing i had a look there and cant find anything that sugests that its a wof fail its no where near the a pillar since its in the boot it doesnt affect the c pillar of any of the bodys strucure the only thing it does is let water into the boot hence why it was sealed up
jakesae101
Postby ryanfels » Fri Oct 09, 2009 8:31 pm
is it within 150mm of the boot hinge?
ryanfels
Postby jakesae101 » Fri Oct 09, 2009 8:37 pm
hinge point i think it may be but again its only where the rubber clips over
jakesae101
Postby Vertigo » Sun Oct 11, 2009 3:21 pm
jake, its really, REALLY hard to read your message :/ please try to at least use punctuation? ta.
Vertigo
Postby Bling » Sun Oct 11, 2009 3:37 pm
Probably makes no difference if its covered in rubber or not, rust is rust.
Postby ryanfels » Sun Oct 11, 2009 3:53 pm
no matter where it is, if its within 150mm of the hinge point, they will fail it.
ryanfels
