DIY Rev limiter
DIY Rev limiter
Postby chrisarmo86 » Fri Oct 16, 2009 3:56 pm
Found this while i was looking for some diy projects, really want to make one now. Have googled like crazy but cant find a tutorial or schematic anywhere. Anyone know a thing or two? I just want a basic rev limiter that runs off a shiftlight, hooked up to a relay that grounds the coil. And no, I dont want a bought one :)
http://www.kerrbrosracing.com/tech_diyrevlimiter.php
My engine wants to be a 3SGTE when it grows up
chrisarmo86
Postby postfach » Fri Oct 16, 2009 4:16 pm
the schematic is on that page Image
postfach
Postby Alex B » Fri Oct 16, 2009 5:01 pm
Lloyd has made a few of them, might even have one spare.
Postby neo » Fri Oct 16, 2009 5:06 pm
remember that relays are slow, thus the limiter is going to be interesting to say the least, not missing every other injection pulse / ignition pulse.
rev spark, rev spark, rev limit flood, no spark flood, rev spark, rev limit flood :wink:
neo
Postby chrisarmo86 » Fri Oct 16, 2009 5:15 pm
if the bee-r ones werent so damn pricey id get one of those. Anyone got a shift light tach they want to swap for a near new blitz F.A.T.T turbo timer?
chrisarmo86
Postby Mr Revhead » Fri Oct 16, 2009 5:27 pm
why do you need one?
Postby kim0663 » Fri Oct 16, 2009 5:32 pm
Mr Revhead wrote:why do you need one?
+1 curious person here.
Mr2 GT-S
330ci M
kim0663
Postby gasman » Fri Oct 16, 2009 5:58 pm
launch control
"What can possibly go wrong?"
gasman
Postby chrisarmo86 » Fri Oct 16, 2009 6:09 pm
launch control is right, plus i have a tendency to be a bit heavy footed, want to keep 500rpm from redline
chrisarmo86
Postby Dunny » Fri Oct 16, 2009 6:11 pm
Try these guys --> http://www.rite-tec.com/
Dunny
Postby chrisarmo86 » Fri Oct 16, 2009 6:36 pm
cheers dunny, but they are a tad pricey dont you reckon? the bee-r ones go for less than that on trade me
chrisarmo86
Postby MR2BOY23 » Fri Oct 16, 2009 6:41 pm
Where are you launching your car?
MR2BOY23
Postby Infinite » Fri Oct 16, 2009 7:03 pm
u cant get a 3sge curren to launch correctly? my curren was powerd by a 3sgte and with the right setup u can get it off the line fine.
Lots
Infinite
Postby chrisarmo86 » Fri Oct 16, 2009 7:14 pm
it doesnt launch too well uphill, which is the only place i really give it the beans. BTW i use the car for hillclimbs.
Also i thing the anti-lag style backfires are awesome, sorry...long time group b rally fan
chrisarmo86
Postby Malcolm » Fri Oct 16, 2009 10:14 pm
Jaycar used to make a kit, I tried to make it but had no idea what I was doing and it didn't work, was doing it in hopes of using it as launch control too.
Postby gasman » Fri Oct 16, 2009 10:16 pm
i used the frequency switch kit and it worked fine
gasman
Postby Lloyd » Fri Oct 16, 2009 11:22 pm
Alex B wrote:Lloyd has made a few of them, might even have one spare.
Just wire it up simple as, shift light output to trip a relay to cut power to the coil. The ones I used were with $30 tachos and worked really well. Limit very cleanly when in neutral and cut in quite soft up in the revs. Plus there is the added factor of them being adjustable whenever you wanted to
Good thing with the tachos I used were that you could fit a relay inside the unit itself, still have the shift light work and still have it as a 4 wire unit. Just ground one wire to the body and have a single run of 3 core wire to the coil. Made for a clean install too as the only wiring you'd see would be one run to the top of the coil
Postby chrisarmo86 » Fri Oct 16, 2009 11:55 pm
which tach's are you refering to Lloyd? What are the chances of getting you to make me one up :) ?
chrisarmo86
Postby Burning Angel » Sat Oct 17, 2009 9:01 am
they were trisco tachs that Repco had on clearance about 3 years ago. they dont do them anymore
1984 SRP61 Starlet
1999 WRX Type RA
Burning Angel
Postby ChaosAD » Sat Oct 17, 2009 9:55 am
What about a gizzmo shiftlight and launch control interface
ChaosAD
