Akane wrote:You can tap your own oil feed with the GE block but what about the piston squirters? People say they're important others say they're not, well take your pick :S
Akane wrote:Is it beacuse the pistons are higher comp that's why it ran really well?
I'm not sure if the original poster wants reliablity or cheap, you can't have both really. I say do it once and do it right, put proper GTE block and pistons in.
