Please help: Clutch master cyl in 4 runner with lexus v8
Postby solberg Fan » Wed Dec 02, 2009 3:11 pm
Does any one know what the size and if it you use the original master cylinder in an old four runner with a Lexus V8 conversion? Im havving clutch problems and im suspecting the master cyl as its been changed at some point.
Thanks
Team KB' Racing
in association with CRC
1981 DX corolla
*My KE70*
Before you judge someone, you should walk a mile in their shoes. That way, when you judge them, you're a mile away and you have their shoes.
solberg Fan
Postby postfach » Wed Dec 02, 2009 3:30 pm
What gearbox are you running? What size clutch master have you got now?
postfach
Postby 3T-Rona » Wed Dec 02, 2009 5:00 pm
how old?
im using the oem 4wd box with a bell housing so ive retained the master and slave just replaced them with new items (bnt, repco, toyota)
PM me for anything autoelectrical, Info or jobs etc....
3T-Rona
Postby solberg Fan » Wed Dec 02, 2009 5:11 pm
Its a 1988 and running the standard 4wd box i believe.
The master cylinder is 22mm but unsure of imperial fraction. It has the markings "M-32" and cant see any toyota markings on it so i guess its aftermarket.
Thanks
Team KB' Racing
1981 DX corolla
*My KE70*
solberg Fan
Postby thegreatestben » Wed Dec 02, 2009 6:33 pm
I had issues when I did a conversion not entirely the same but I couldn't get the right amount of throw to completely disengage the clutch unless it was completely on the floor.
Issue was related to the release bearing being too "stubby"
thegreatestben
Postby solberg Fan » Wed Dec 02, 2009 7:04 pm
Yeah that was my first thought but i changed it to a longer bearing but its still along way of disengaging.
Any one else?
Team KB' Racing
1981 DX corolla
*My KE70*
solberg Fan
Postby 3T-Rona » Wed Dec 02, 2009 7:12 pm
change the length of the rod that pushes the fork, or would that load up the bearing to much.
3T-Rona
Postby solberg Fan » Wed Dec 02, 2009 7:47 pm
The 2nd thrust bearing I put in had the push rod pressed up hard against the fork. I figger it should actually have a bit of clearance so the bearing isnt turning all the time.
:cry:
Team KB' Racing
1981 DX corolla
*My KE70*
solberg Fan
